Old 12-06-2004, 12:14 AM   #1
68jimmy
68jimmy's Avatar
Lowering blocks...
What is the max on can obtain with lowering blocks? I just recently swapped my leaf spring setup for a 1/2 ton coil setup and I'd like to drop the rear a bit more. I was thinking of using some 2x3x6(?) rectangular tubing and using the 3" side for the drop... If ok do I need to weld up the ends? or is 3" too much for blocks?
thanks!
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 12-06-2004, 02:35 AM   #2
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
as long as tghe blocks are strong, and you have U-Bolts, you can go as big as you want. However I wouldn't go over 4 inches cause then the trailing arms will hang really low. You can use that box tubing, but get 1/4 inch wall thickness and definitelly box the ends.
Bagd72Chevy is offline   Reply With Quote
Old 12-06-2004, 02:41 PM   #3
68jimmy
68jimmy's Avatar
thanks for the info...
Old 12-06-2004, 03:45 PM   #4
smokekiki
Mike
smokekiki's Avatar
The problem with going to big on Your blocks is the u-bolts and or trailing arm get lower than the wheel.It will not be a good thing if You get a flat.You can get a good set of springs for around $100.00.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 12-06-2004, 03:56 PM   #5
smokekiki
Mike
smokekiki's Avatar
read,and look at the pic in this thread...http://67-72chevytrucks.com/vboard/s...owering+blocks
