Old 12-09-2004, 01:20 PM   #1
sam's 72
Truck will not crank over!....HELP ME!!
My son has a 98 chevy truck. ( I wanted to post here due to getting more hits ) The other night it would not start. Cranked over like a dead battery. So he put a new starter on it. ( Bought from chevy dealer ship ) still would not crank over.( Sounds like a dead battery, just barely rolls over ) The battery is a side mounted post, I checked it out and it looked bad to me. Where the cables hooked up, you could not get the positive side tight. So I went down bought a top mounted battery, and put it in with all new clamps. The battery is showing 13.8 volts. Still the same thing. When you hit the key, it turns over like a dead battery, just barely rolls over. I do not understand what could be wrong here? All the wire going to starter is good, all connection are good. There is a wire that runs over to an electric box under hood that has a lot of fuses and relays in it. There is a starter relay in this box. Do you think this could be the problem. I figured if the relay was bad, it would not even roll over. What do you guys think??????????. Help me out guys
Sam
72 LWB chevy truck.
Pasadena, Texas
sam's 72 is offline   Reply With Quote
Old 12-09-2004, 01:32 PM   #2
garold99
If you only changed the connector clamps on the positive battery cable then it still might be a bad positive battery cable. Might be broken or burnt or have some corrosion on the inside of the insulation somewhere and the outside still look fine.
garold99 is offline   Reply With Quote
Old 12-09-2004, 03:32 PM   #3
sam's 72
Found the problem! It is the starter. This starter was bought last night from a Chevy dealer ship. I pulled it off and took it down for testing, came back no good! Waiting for my son to come home and go get his money back or get another starter. I have had this happen now four time in my life of working on these trucks. It is a crying shame that we can not get quality parts any more. Thanks for all the outsourcing, but that another subject!
Sam
72 LWB chevy truck.
Pasadena, Texas
