Old 12-10-2004, 11:44 PM   #1
WILLNIK
? for the experts on the front cross member
Probably a dumb question, but here it goes. While installing the new front cross member, the bottom two bolts go through a welded nut on the cross member. (72 1/2 ton 2-wheel drive) These don't line up perfectly, off just enough so I can't get the bolt started. Can I remove the welded nuts and use the lock washers and nuts provided in the stainless kit I bought? Or do I keep adjusting it until the original welded nuts line up?
Thanks, Terry
50 miles west of Syracuse, NY
'94 Silverado swb
'70 Chevelle
'65 Corvette roadster
'11 Tahoe (wifes ride)
WILLNIK is offline   Reply With Quote
Old 12-11-2004, 04:35 AM   #2
68LSS1
68LSS1's Avatar
What year is the crossmember out of? I'd do everything I could to try and get it to work as the last thing you want is a crossmember that is not square to the frame. If I couldn't do that, I'd probably open the holes a little and retain the welded nuts. As far as the structural integrity, there would be nothing wrong with removing the welded nut and installing a lock washer/nut of proper grade either. My aftermarket cossmember is entirely bolted in using SS fasteners also.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 12-11-2004, 08:02 AM   #3
WILLNIK
68LSS1,
Thanks for the reply. The cross member is out of a '72 1/2 ton 2 wheel drive. The frame is a '70 short wheel base frame. I can get two out of the four lined up (one on each side), but the other two are off just enough so I can't get the bolt started. Did GM install these then tack weld them? I will go back today and try again. Thanks again, Terry
'94 Silverado swb
'70 Chevelle
Old 12-11-2004, 08:37 AM   #4
tommygfunk
tommy . master of madness
tommygfunk's Avatar
my swap
I put a 87 crosses member and complete suspension and steering into my 67 short step the 4 bolts 2 of what you are speaking I rounder out the holes on the frame. You have more than enough bolts to line up and keep the c/m straight on the frame. Let me know if you need anymore help.
The swap was easier than I thought it would be. There is verry little differences between the two c/m’s
The master of all I see in the never-ending madness that is my life.
1967 C10 frame off project [the wife's wedding present] "Lacey"
“Only a man so smart can act so stupid!”
Tommy G. Funk
tommygfunk is offline   Reply With Quote
Old 12-11-2004, 02:13 PM   #5
Bob Moore
Fitting crossmember
You might have to leave the three vertical bolts through the frame rails loose until you get the lower 2 horizontal ones started. After you get them started you can go back and forth with the lower ones until all are tight.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 12-12-2004, 11:08 PM   #6
WILLNIK
Thanks for the replies. Anyone else? Terry
'94 Silverado swb
'70 Chevelle
Old 12-12-2004, 11:40 PM   #7
68C15
blood type; Retumbo
68C15's Avatar
I think what he is talking about is the pieces that bolt to the Xmember & thwe frame. (on the outside of frame where the upper arms connect)
I removed the welded nuts & installed lock washers & regular nuts myself. I believe there was a difference in the bolt size. one was 7/16 & the other was 1/2 I think.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 12-13-2004, 12:07 AM   #8
silvertonguedevil
silvertonguedevil's Avatar
I bought a '70 shortbox frame that had no front suspension under it at all and I then slid a '72 rolling cross member under it. I never ran across any welded nuts Did somebody already get rid of them?
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 12-13-2004, 01:45 PM   #9
67ChevyRedneck
67ChevyRedneck's Avatar
I put a 71 gmc disk brake set up in my '67. I had the exact same problem you did....I worried if I enlarged them I would mess up the front end alignment...after MANY frustrating hours I installed the front two bolts, took measurements for squareness, tightened them down, and enlarged the other two holes. I then rebuilt the entire suspension and disk brake assemblies with ALL new parts. Long story short I was afraid that when I took it in for the alignment they would say it was messed up...but the guy told me I did an excellent job, all he had to do was adjust the camber on the driver side 1/16". Also, the alignment shop was a specailty place here in town that does nothing but alignments and brakes. 6,000 miles on new front end...disk brakes are awesome...NO vibrations, NO unusual tire wear. I say do what I did, be careful, and enlarge them.
67ChevyRedneck is offline   Reply With Quote
Old 12-13-2004, 02:20 PM   #10
Slammed67
Progress = 0%
Slammed67's Avatar
The weld nuts are located on the upper a-arm brackets as pointed out in the pic below....
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 12-13-2004, 04:20 PM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You guys worry a lot sometimes.
I know a guy who used to swap the crossmembers and leave those 2 bolts out rather than worry with grinding the holes.
No ill effects were ever noted after driving the trucks for many miles, and the dude eventually grew up and turned out just fine......me!
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-13-2004, 06:56 PM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Tx Firefighter
....the dude eventually grew up and turned out just fine......me!
Can we vote on that.... :p
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-13-2004, 09:33 PM   #13
Solver
Solver's Avatar
Talking
Sounds like a good poll question but I don't think Tex would like us and most of us haven't even met him :p .Oh well Gotta question the sanity of most of us that live on this board!!
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 12-13-2004, 09:36 PM   #14
Tx Firefighter
I think I'll just go back over to my welding forum boards now.
Old 12-13-2004, 10:38 PM   #15
tommygfunk
tommygfunk's Avatar
call ed
at mothertruckers. he helped me swap the 87 to my 67
Tommy G. Funk
Old 12-13-2004, 10:57 PM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
Ahh man don't get your feelings hurt.....
Old 12-15-2004, 07:26 PM   #17
WILLNIK
Thanks for all the replies! Sounds like enlarging the hole is the way to go. Terry
'94 Silverado swb
'70 Chevelle
Old 12-17-2004, 12:46 AM   #18
GlennBrittain
I have plans to change my 69 to a later model front end for the disc brakes also. I can get a 73 from a chopped up truck free if I do go this way.I need to decide if this is the route I want to go or buy the disc brake conversion kit that is available from several sources. That is if I get started on mine again, building projects keep gettin in the way. I would like to know if you have any spacers to install to square up the front clip when bolting it on
GlennBrittain is offline   Reply With Quote
Old 12-17-2004, 02:47 PM   #19
WILLNIK
The front cross member I am talking about does not have any spacers that mount to the frame. (There are spacers and shims on the upper control arm studs.) Front clip (sheetmetal) spacers (shims) should be able to be purchased through any of the board vendors.
Terry
'94 Silverado swb
'70 Chevelle
