Old 12-12-2004, 11:05 AM   #1
Mike Culpepper
Red
Mike Culpepper's Avatar
Next Step?
I thought I' had solved my battery draw down problem by finding a loose connection, but the problem is still there after I fixed the wire. I attached a test light between the neg. battery post, (neg cable removed first), and the large red wire at the alternator and the test light lights up. If I understood ya'll correctly, this should NOT happen if the electrical system is fine, right? So that means that SOMETHING is drawing power from the battery overnight, right?
I pulled fuses one at a time, and the light NEVER went out!???? Where would ya'll suggest going from here? For what it's worth, the test light did NOT light when I touched the smaller dark blue wire at the alternator.
Mike
'72 Cheyenne LWB 350/350
"The sun don't shine on the same dog's ass all the time." - Catfish Hunter (commenting on why he was not able to pitch another perfect game).
Mike Culpepper is offline   Reply With Quote
Old 12-12-2004, 12:50 PM   #2
Randy70C-10
Randy70C-10's Avatar
If you connect the negative post to the positive wire on the alternator it will light up because you've completed the loop! What you need to do is re-connect the negative, dis-connect the positive and run the dummy light from the positive post on the battery to the positive battery cable. If it lights up then you start pulling fuses. Good luck!
Randy70C-10 is offline   Reply With Quote
Old 12-13-2004, 11:11 AM   #3
Mike Culpepper
Red
Randy,
Thanks for the clarification, I feel as dumb as a rock when it comes to electrical stuff.
Mike
Old 12-13-2004, 11:20 AM   #4
70c10
67-72 Addict!
70c10's Avatar
Mike, check this out:http://67-72chevytrucks.com/vboard/s...d.php3?t=33198
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-13-2004, 12:23 PM   #5
Mike Culpepper
Red
Jim,
thanks, I saw that earlier this morning, and for me a pic IS worth a 1K words!
Mike
