Old 12-09-2004, 09:49 PM   #1
Ron
Ron's Avatar
700r4 and t-case
I've had a Chev 350/727/Dana 20 in my Scout for years. This is a DD and fuel milage has become an issue. I have a good 4.3/700r4 out of an Astro van. Been thinking about installing it. Is this 700r4 a good candidate for a 4X4 application? What would I need to hook it up to an Atlas or D300 t-case? The vehicle weights in at 3,900 lbs now with the V-8. Would the Scout be grossly undered power with the 4.3? Give me some feed back. My target is 20 MPG. Also, is there a good S-10 web site that I could post this trend? Thanks
'69 SWB
'76 International "Terra"
"Hooked on holiday beer"
Ron is offline   Reply With Quote
Old 12-09-2004, 09:58 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I think the 2wd 700R4s are not as strong as the 4wd 700R4s. Then you'd have to open it up and replace the output shaft as a minimum plus get and adapter.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 12-13-2004, 11:35 AM   #3
Gunny
runnin on empty
Gunny's Avatar
at the local pick n pull yard here you can get a mated 700r4/np231 from an s-10 for $100.00 - so you may want to check your area to see what the price range is
88 GMC Suburban - 6.2 Diesel 4x4
87 Jeep Cherokee - 6" lift, 32 bfg's, way too many mods to list.
65 Thunderbird - Stock
United States Marine Corps
SEPIUS EXERTUS, SEMPER FIDELIS, FRATER INFINITAS
"Often Tested, Always Faithful, Brothers Forever"
Gunny is offline   Reply With Quote
Old 12-17-2004, 12:18 AM   #4
goldwing2000
goldwing2000's Avatar
Why not stick with the 350 instead of switching to the 4.3?
~Kane
USMC
NRA
GWRRA
AMA
Remember:
Except for Slavery, Fascism, Nazism, Totalitarianism and Theocracies,
WAR HAS NEVER SOLVED ANYTHING!
goldwing2000 is offline   Reply With Quote
