Old 12-17-2004, 01:24 AM   #1
pickngrin2
gas mpg
what would a stock 283' and stock drivetrain get mpg?
pickngrin2 is offline   Reply With Quote
Old 12-17-2004, 12:40 PM   #2
60-66 Nut
Professional Beer Tester
There are alot of variables that can affect fuel mileage, so this is probably just a close guess. I guess you are referring to the drivetrain of a 63-66 1/2 ton pickup, probably with a 3 spd standard or powerglide. I don't know what rearend you have but the most common was the 3.73. It also depends on what carburator the 283 has, I think the trucks only came with 2 bbl carbs back then but anything could have been put on the engine. Some 4bbl carbs can actually get better fuel mileage than a 2bbl because of smaller primary jets and venturis, providing you drive it easy and stay out of the secondarys. My best guess would be around 12-14 mpg, maybe a little better with the right conditions. Maybe someone that has one with that combination can give you some more accurate numbers. Years ago I had a 65' with a 327 4bbl, 3 spd and 3.73 rearend, 10-12 was about the best it got but gas was only forty cents a gallon. You could probably do alot better with a 3.08 gear and an overdrive trans. Hope that helps.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
