07-04-2002, 09:57 PM | #1 |
Help: Starter problem
Tried to start engine today for the first time. It cranked slow then tore all the teeth off the starter. The engine is a 454 and was professional built (high compression). I shimmed the starter when I put it on. It was just a stock starter. Is the problem that I need a high torque starter or could it be something else?
72 Chevy A/C P/B P/S Tilt 454 Engine 400 TCI Trans C30 Frame C10 Suspension Short Wheel Base (Dually) |
07-04-2002, 10:01 PM | #2 |
its all about the +6 inches
HOLEY SWEET MOTHER!!!!!!
What kind of compression you have in that machine??? Actually, see if you can turn it over by hand(after removing all the plugs). I suspect something is in a cylinder that is preventing it from moving. (a dropped valve, a sideways piston, your rachet that you lost...ect) |
07-04-2002, 10:08 PM | #3 |
Have been turning engine over by hand on a regular basis (no plugs). Actually cranked engine with starter for a few revolutions just prior to installing plugs. Put plugs in, cranked engine, teeth be gone!
07-04-2002, 10:34 PM | #4 |
Too much shim? (maybe)
07-05-2002, 09:58 AM | #5 |
Registered Cruiser
Do you have the right starter for your flexplate/ring gear?
I intend to live forever. So far, so good. |
