Old 12-21-2004, 12:50 PM   #1
Wootdog
Wootdog's Avatar
License plate insert
I recently saw a weld in insert for holding a license plate in a tailgate. I don't remember who the manufacturer was. Any one remember seeing something like this on TV? Thanks in advance Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 12-21-2004, 08:49 PM   #2
flatblack67c-10
flatblack67c-10's Avatar
Sir Michaels makes these inserts, and they are fairly cheap too.
www.sirmichaels.com
was 67 chevy swb fleet now muticolored 69 step, 350/350, 3.73 posi, converted to 5 lug, torq thrust II 17x8 front 17x9.5 rear, factory air cab, fuel cell. future plans: shaved wiper cowl, shave stake pockets, phantom grille, and silver paint...
68 camaro ss396 project
54 f*rd project truck
flatblack67c-10 is offline   Reply With Quote
Old 12-21-2004, 09:22 PM   #3
Randy70C-10
Randy70C-10's Avatar
Here's the link to the page they're on ...... http://www.sirmichaels.com/fraccess.shtml
Randy70C-10 is offline   Reply With Quote
Old 12-21-2004, 10:06 PM   #4
Wootdog
Wootdog's Avatar
I will call them in the am. Randy I probably will need you to weld the box in and help me put the tailgate on. Need to put some brackets on the bed to keep the tailgate up. Getting the front end aligned in the am. Maybe come out to your house tomorrow. I will call you. Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 12-21-2004, 11:09 PM   #5
bagged91
Out draggin'
bagged91's Avatar
They are easy enough to make if you have the time(20-30 minutes). Get a piece of 18ga. steel a little larger than your plate and about 3-4 feet of 1 1/2" 18 ga strap. Take your tag, trace it onto the steel including your mounting holes leaving about 1/4-3/8" all the way around the tag. Use a plasma cutter, bandsaw, jigsaw, air nibbler or airshears or small anglegrinder(4 1/2") with a cut off disk and cut out the shape. Drill out your holes for tagscrew inserts. Fire up your mig and start tacking the strap around the edges wrapping it around the corners. Once welded, it makes a nice tag box with radiused corners instead of just a plain square box. You can integrate either an OEM type flush mount tag light into the box or use a lighted billet tag frame.
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 12-22-2004, 12:38 AM   #6
Randy70C-10
Uhhhh, ok. Hey, if you guys haven't seen Kerry's badass truck yet, check it out! http://207.44.196.117/vboard/showthread.php3?t=132533
Old 12-22-2004, 10:43 AM   #7
GreyHoundSteve
Thats a good lookin stepside. Beutiful motor too.
GreyHoundSteve is offline   Reply With Quote
