![]() Join Date: Dec 2001
CPP also sells rear disc brake kits; it is bolt on except for a tab for the emergency brake (if you want to run an e-brake) that welds onto the rear axle. The grand slam kit had everything I needed to rebuild my front and rear suspension, front brakes, and drop how much I wanted.
Their rear disc kits are $599, look on page 2 of the truck section. If you need to rebuild your suspension the grand slam is great, I absolutely love mine. If not, they sell drop kits with spindles, rotors, calipers, that utilize all your original tie rods, ball joints etc.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
I think ive decided to just get some 6 lug front rotors for now and worry about the rest later. My near drums just got rebuilt so i guess i shoudl drive it awhile before i worry about upgrading them.
On a side note. Does anyone know the rim lingo for the 6lug patern? |
#3 | |
![]() Join Date: Jul 2003
Are you planning on going with and aftermarket wheels? The reason I ask is that there are way more wheels out there to choose from if you went with 5 on 5 lug pattern. BUT they are starting to get alot more 6 on 5.5 now because of the newer trucks and SUVs that have the 6 lug rotors.
1968 Chevy C10 Short Fleetside/Wood floor ECE 4-6 Drop / 406 Small Block 1971 Chevelle 427 Big Block |
#4 | |
Got Light Emitting Diode?
keepin it original with tha 6 lug...................well kinda
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
Im trying to decide between these:
the last set out of those three
#8 | |
The last ones are Eagle026 the first two are Boss 311 and 301. I'd like to do 20x8.5 in front and 20 or 22x 9.5 in back. Anyone knwo what backspacing i would need on a 4/6 drop? |
