Old 12-26-2004, 11:17 PM   #1
fossilrunner
fossilrunner's Avatar
can't decide
I have narrowed my choices down to two shifters but can't decide which to get.It will either be the b&m pro stick or the pro rachet. What are the diffrences between the two?
71 chevy lwb w/ 350,750 holley 4150,edelbrock performer rpm,full 2 1/2 exhaust exit out side,6-8 drop,rally wheels.-SOLD
74 Chevy nova-355 with a little nitrous
78 GMC Jimmy 4x4-Factory 400 and all stock.
fossilrunner is offline   Reply With Quote
Old 12-27-2004, 04:40 AM   #2
68LSS1
68LSS1's Avatar
The "ratcheting" shifter handle stays in the same position irregardless of the gear your in. Meaning you can smack it forward or back wards and with each hit it moves to make the shift then returns to the original position. For example to go from neutral to L1 would take 3 separate tugs on the shifter. With each tug the tranny would drop a gear but the shifter handle stays in the same position, it does not move up and down the gate. I'm probably making this harder than it needs to be but I'm having trouble describing how it works. The Pro Stick is similar except that no matter how hard you hit it, it will only make one shift but the shifter moves the length of the gate. They both have a reverse lock out (a tab you will have to move to get into reverse).
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 12-27-2004, 11:44 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I had a ratchet shifter and did not like the way it worked JMO.... I do have a b@m star shifter and love the way it work's and it is not a ratcheing style of shifter...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-27-2004, 01:53 PM   #4
68LSS1
68LSS1's Avatar
Ya, they do take some getting used to. Definately a strip type shifter. I like them especially on a reverse valve body tranny. But a lot of people find them to be a pain.
'68 Short Step
