Old 07-06-2002, 08:32 PM   #1
John Fabris
TOTY 2006
John Fabris's Avatar
Power Steering pump Pulley....
Hi All,
On trying to remove a P/S pulley, I was able to remove one that is a two groove pully with a nut on the end of the shaft, but now I am trying to remove a single groove pulley where the pump does not have a nut, but the shaft is hollow and has threads. Using a two arm puller, I only end up pulling chunks of metal off of the center of the pulley.
What is the correct way to do this?
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 07-06-2002, 08:42 PM   #2
jostrans68
Jostrans68
jostrans68's Avatar
napa has a puller for this its about 30.00 but it saves pulleys my advice is to put a hose clamp low on the jaws and tighted helps it not to move, I have pulled many of these when I worked in the parts stores and this worked the best. My .02 worth
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
