Old 12-30-2004, 06:50 PM   #1
bagged72blaz
Got L.E.D.s
bagged72blaz's Avatar
Question Gas Tank filler behind side marker?
I was curious if anyone here has done this, and how to go about it? I think it would be easier than behind taillight.
Bagged 1972 2wd Blazer
http://www.earlyclassic.com/home.aspx
bagged72blaz is offline   Reply With Quote
Old 12-30-2004, 07:50 PM   #2
71swb4x4
71swb4x4's Avatar
I don't see why it wouldn't work just like it did on pickups.
Have you seen this thread?
http://67-72chevytrucks.com/vboard/s...d.php3?t=77104
I did it on my short/fleet this summer, not too tough.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-31-2004, 09:10 AM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
VERY NICE WORK
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-10-2008, 03:32 PM   #4
Duner97
Duner97's Avatar
Thumbs up Re: Gas Tank filler behind side marker?
Do it! I did it to my truck. I've gotten several oohs and ahhs. its a nice custom touch if you have the time to rig it up. I really just 'winged it.' cut here, there, weld this to that, add a screw, welded different filler tubes together. I had a body lift, so that really helped with running the filler above the frame rail. I'm not too sure how you would want to go about that with your blazer. At least you're not in CA and don't have to worry about those bulky rubber boots on almost all the pumps!
72 SB 4x4
-Duner97
Duner97 is offline   Reply With Quote
Old 01-10-2008, 04:22 PM   #5
Topfuelflat
Topfuelflat's Avatar
Are there any other ideas on where to put the filler neck on a Truck/Blazer other than stock.
72low
Topfuelflat is offline   Reply With Quote
Old 01-10-2008, 04:39 PM   #6
71swb4x4
71swb4x4's Avatar
Here's another great one. Wouldn't work very well if you had a Blazer running a hard top though
http://67-72chevytrucks.com/vboard/s...d.php?t=211579
Old 01-10-2008, 04:39 PM   #7
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Here's a build thread from a member. He has a Stepside. I am going to do the same thing in my 69 step side
http://67-72chevytrucks.com/vboard/s...ad.php?t=77104
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 01-10-2008, 06:14 PM   #8
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Wes at classicheartbeat.com has a write-up on how to do the side marker setup on his website.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 01-10-2008, 06:31 PM   #9
HuggerCST
HuggerCST's Avatar
Here's what I did with mine.(tail light) I think if I were to go with the side marker filler, I'd use the hagan filler and cap. Kinda like another member did below, but I would try to attach the marker light to the hinged piece. With this cap there is no need to reach into the small light opening to remove the cap. Simply swing the side marker door open and insert the fuel nozzle into the center flap.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 01-10-2008, 06:42 PM   #10
Topfuelflat
These are all really great ideas.
72low
