Old 07-05-2002, 08:16 PM   #1
toolman70
ignition
Thanks 68 step side.....with your info I got the ignition switch right out !!! Now heres another question. If the key does all of its functions,except turn off the engine, do I need to replace just the switch or both the switch and the tumbler...Thanks again to 68 step side
1970 CST20
toolman70 is offline   Reply With Quote
Old 07-05-2002, 08:21 PM   #2
68 Stepside
huh?
68 Stepside's Avatar
Hey, no problem.
Are you positive the switch is bad? What type of ignition is on the truck? Points or HEI? I wouldn't go buy a new switch until I was 100% positive it was the switch causing the problem, and not the coil wire either A. Touching a 12 volt source, or B. Hooked up to a 12 volt unswitched source by accident.
TJ
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 07-07-2002, 04:12 AM   #3
68 Stepside
huh?
Hey toolman,
How'd everything work out? Get her fixed?
TJ
RIP El Jay
Old 07-07-2002, 06:18 AM   #4
toolman70
The bad news is I had to order a new switch.should be here by wed. or thur.. The good news is I got to order a couple of other things I've been wanting.
1970 CST20
