01-01-2005, 10:29 PM | #1 |
Got Light Emitting Diode?
what i did today
these are pics of what i did today. very straight forward, i read longhorn man's write up and i thought it would be more difficult but it was done in 45 minutes, and that was only because i didnt have the donor piece from the truck for the horn so i had to sodder (sp?) the wire to the spring, but all works
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
01-01-2005, 10:51 PM | #2 |
Born To Lose Club
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Sweet, Whatcha gonna do with the old wheel?
Brian Smith - "Born To Lose" 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
01-01-2005, 10:53 PM | #3 |
let it sit the garage and collect dust unles someone wants it
01-02-2005, 12:31 AM | #4 |
pic
01-02-2005, 01:05 AM | #5 |
its all about the +6 inches
Sweet...I just have one question.... WTF is the red thing covering where your ignition switch goes?
The wheel kicks ass doesn't it? Pulls it away from your chest a little, and is WAY more comefortable. |
01-02-2005, 01:21 AM | #6 |
its a start button out of a Hond@ S2000. i turn my key to the auxiliary position then the button lights up (it says 'ENGINE START') and i push the button the ignition i made a bracket for and is moved under the dash. you can see the key hanging in the red square. the turn signal lever is close to the wheel, if i would have known that i would have taken it off and done a little 'adjustment' to it to have more clearance but it all works.
01-02-2005, 01:29 AM | #7 |
interesting indeed.
As for the turn signal...I never really noticed that. I wonder if the PO might have bent yours back a little. |
01-02-2005, 01:36 AM | #8 |
i can barely fit my finger between the wheel and the lever. are the wheels you used the same as this one??? maybe they have a different dish to em. this one measured 4 1/16 from rim to base. my original was 5 3/4
01-02-2005, 02:15 AM | #9 |
68w
I'll take another look at how bad mine is tomorrow since I haven't looked at it for 6 months. I'll let you know tomorrow about your old wheel. Thanks, Mark
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
01-02-2005, 02:25 AM | #10 |
sounds good
01-02-2005, 03:26 AM | #11 |
hart
68w/sbc406- the gauge you put in the dash did you use a hole saw to cut the hole? I am a little afraid of cracking something. My hole saw is for wood got some pretty big teeth.
01-02-2005, 03:59 AM | #12 |
yeah it was a hole saw for wood. just go slow and it will mostly melt though. then i needed to take a flapper wheel and a die grinder and make it bigger cause the hole saw i had was a little too small. and if it cracks, i have seen these particular clusters go for like 15 bucks on e bay. thats my water gauge, i got the oil presure on the other side
01-02-2005, 09:08 AM | #13 |
I like your start button. I was thinking of doing the same thing on my truck. Guess I can't be the first now. LOL Did you use the original ignition switch under the dash? Was it easy to wire up? How much was the switch?
I noticed it on the new Viper engined Dodge Ram and liked the idea.
1972 Blazer body...need to get a thread started for the rest of the story |
01-02-2005, 10:03 AM | #14 |
It sounds like your lever has been bent. I can't recall exactly how much room I had, but it was more than that.
01-02-2005, 11:15 AM | #15 |
Left Foot Functioning
Nice shop table. Me likes Goats...
Thanks for the write up/pics...will be useful. I had a the same clearance problem with the turn signal on a plain-old Grant wheel. Pretty stock truck, don't think the lever was tweaked previously. SSOW
69 C10 (#1 son's ride) 72 C20 (Dad's farm truck) 82 K30 (Ex - brush pumper project) |
01-02-2005, 01:18 PM | #16 | |||
o its a 67 if you couldnt tell
01-02-2005, 03:18 PM | #17 |
Anyone know what a good diameter and backspacing is for a 72 without tilt? I was thinking of a wheel that is about 14" with 3 3/4" dish, but if it interferes with the turn signal arm I won't bother. I suppose there is also the shifter to worry about too. I will be switching to a billet shifter too, whether that makes a difference.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33703 That's the shifter I'd be using with that wheel.
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
01-02-2005, 03:35 PM | #18 |
well that wheel has a dish of a little over 4 inches, not sure about the diameter, i didnt check that. as far as the turn signal, just bend it a little, and i cant help you with the auto shifter, i dont have one
01-02-2005, 05:01 PM | #19 |
Yeah, when you remove the wheel, you'll see there is one screw holding the turn signal lever on. you can remove that and bend it a little to make it straight instead of bent towards you, or if you wanted, you could even put it on backwards and have it so you'll never accidently hit it...but I wouldn't know why you'd wanna do that.
01-02-2005, 05:15 PM | #20 |
yeah when i first got my truck my auto canceler didnt work so i have already replaced that piece that it screws to. my dad bought a wheel puller so i could fix it. i am glad he did cause i think that i am still the only one to use it and i have owned my truck for 3 years. thanks for the write up andy, and the help on all other projects you have comented on.
01-02-2005, 05:22 PM | #21 |
If that's a 2dr GTO, I'd like to have a table like that...
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
01-02-2005, 10:42 PM | #22 |
they dont make 4dr GTOs. they have hard top, post, and convertable. that one is a hard top which i think looks better but the posts have a lower production number
