Wanted to buy!!!
I am in need of an Alt bracket for my 67 c10 2wd lwb! I need the one that does not require drilled and taped holes in the head! (I have none.) My alt is mounted on the drivers side above the power steering pump the old bracket mounted to the exhaust manifold but I have installed headers so It no longer works!! Any Help????? (I have the 283cid)
![]() Join Date: Apr 2004
If you can not find the factory brackets they have after market brackets for this very problem.
1968 Chevy 4x4 307 4 speed |
Truck Farmer
Header brackets
25. shipped to your door. Chuck
Arizona rust free sheetmetal |
#4 | |
brackets
Say, -I have 2 brackets left over from a Hooker header set that I bet are what you are needing. Can send a pic if you want to see them. -steve
Man I need a pic of this set-up. I cant seem to figure out what I need!!
Alt.
This is what I have, a complete set. I hope this helps.
Better description.
Header bolts go in bracket 1. Bracket 2 mates to bracket 1 as red lines indicate. Alt. large bolt goes in bracket 2 and bottom of alt. Bracket 3 hooks to water pump and slot is for top alt adjustment bolt.
#8 | |
The stuff mike Files has looks like what will work. I'm missing one from my hooker set, unless I can find it. What Mike shows less the sloted belt adjust arm is what my illustration shows. [Hooker paperwork] I'll scan it and post it. -Steve
pic of Hooker lit.
Give me your email and I'll send it that way. If I resize it again I don't think it'll be clear. Send it in a PM. -Steve
