Need Gauge Wiring Harness
I am converting my truck from the basic gauge dash to a complete gauge dash (with the lower gauges - voltage, oil pressure, etc) I already have a nice complete gauge cluster and new dash bezel. I was going to rewire the plug so it matches and run individual circuits for each gauge but a different plug and harness would probably be easier. Does anybody have a new or used gauge wiring harness with plug which will match the complete gauge cluster I now have. Also, how hard is to to rewire the gauges with the different harness?
You must change the dash harness and the engine harness as the wiring is totally different. Make sure you get the stuff from the same truck. I have run in to that before and it was a 70 with lites and put a guage harness in it(i didn't know then) and hooked the bat up and FIRE !!!!!!!!!!! i got it out and found the difference. I just dont want anyone else to have that problem. As long as you get it all from the same truck with guages you will be fine. Its not that bad to put in too. Hope this helps a little,Erick
