Still drivin' a Rat Rod
Will the defroster vents interchange?
The reason I ask is the right vent defrosts the glass about the the middle in front of the passenger,and the left one defrosts the bottom of windshield,and towards the middle of the glass,over the speaker,and the area in front of me is the last to clear.
Is it possible that it has 2 right hand vents?WIll they both fit in either place?It seems it would be blowing the right place if I turn it around,but the direction the hose fits on the bottom is angled the right direction.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
Watch out for your cornhole !
![]() Join Date: Jun 2003
The left and right vents are different. One has a round hose fitting and the other is an oval.
It's been awhile since I put any in, but there is a notch that needs to line up with the dash if I remember correctly. You'd have to remove the notch.
defroster vents
If you put the passenger side on the driver side, you can't hook up the hose. It gets into the instrument panel. Already tried it. Mine work about the same as you're describing. Frank
