#1 OU Soonerfan
Annoying Leak............help!
Hello guys, I have this damn leak in the top right corner of my windsheild. When it rains, it leaks straight into my cab, inside the glovebox, and ending on the rubber floormats. Any answers to solve this problem would be wonderful!
![]() Join Date: Nov 2004
Lift up the rubber and see if you can see the hole. If you can try to squeeze some weatherstipping adhesive in there. That might fix it for ya.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
67-72 Addict!
It might be leaking at the antenna. You should pull out the glovebox and look for daylight.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Still drivin' a Rat Rod
Could be from the drip rails too.That's where mine leaks at sometimes
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
I had exactly the same leak on my K20. I lifted the rubber on the window and stuffed it full of sealer but it did not stop. I started lookiing for a liquid sealer that is on the market that you can drip behind the seal but I never did find the name of it. Maybe someone else might know where to find it.
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
Where's my beer?
I'm not sure if this would be possible, but if you could sprinkle some powder around the windsheild seal and then hit it with the hose, if the powder gets washed away, you've found your leak.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
If it is the windshield, you can try flowable silicone. It is made for that application.
I purchased some a while back from LMC. |
#1 OU Soonerfan
thanks for the info guys!
It might be worth pulling the window and taking a good look behind the rubber seal. Had the same isue on my back window. The rust had eaten away part of the window frame whcih caused the seal to expand and create a leak. Flowable silicone might be a good temporary fix but make certain you fix the real cause before the damage becomes huge. It wasn't to hard to clean mine up, welded up some small pin holes and ground away all the surface rust.
