Old 01-08-2005, 02:02 AM   #1
bagged72blaz
Got L.E.D.s
bagged72blaz's Avatar
Question Volume of air per bag/air storage? How do you measure air gallons?
Ok I'm going to be redoing my air set-up soon. Want to get the 5 gal tank out of the inside of my blazer. Put everything under body. Build custom 4" round tanks. I know that you measure air gals, different than liquid gals.
What is the formula? How long would I need to make a 4" pipe to get 3 gals?
I'm wanting 3 gals per bag, 4 tanks total, each tank as close to the bag as possible. I'm going to mount the front valves on top of the frame rail inside the engine compartment so they don't freeze up. The rear valves I'm going to put inside in the bed area with the dump routed out side. Or maybe close to the exhaust(not to close!) I'm going to add another compressor. Any recommendations? Need 100% duty, sealed, as I'm going to mount inbetween frame rails. Thoughts
Bagged 1972 2wd Blazer
http://www.earlyclassic.com/home.aspx
bagged72blaz is offline   Reply With Quote
Old 01-08-2005, 03:02 AM   #2
bagged74
its just $$$$$
bagged74's Avatar
I thought a gallon was a gallon, no matter what you were measuring.
bagged74 is offline   Reply With Quote
Old 01-08-2005, 03:51 AM   #3
Shane
Shane's Avatar
Volume of a Hollow Cylinder in Cubic Inches:
V=3.1416ht(D-t)
V=volume-------------------(3 gallons)
h=height/length of cylinder---(dunno ... that's what we are solving)
t=wall thickness-------------(you got to tell us this)
D=O.D.----------------------(4 inches)
Now convert Cubic Inches to U.S. gallons:
231 cubic inches = 1 U.S. gallon
693 cubic inches = 3 U.S. gallons = Volume
Now solve for h
Hope this helps.
Shane is offline   Reply With Quote
Old 01-08-2005, 11:10 AM   #4
SCOTI
SCOTI's Avatar
I don't think there is a difference of air vs. liquid as far as packaging size is concerned. A 5gal container for air, would be a 5gal container for water. The big difference would be the density of each substance & how much you could pressurize each within that container.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-08-2005, 02:10 PM   #5
Shev
Head Peon
Shev's Avatar
Man I hope you know what you are doing making your own tanks. Here's one guys way of making his own tanks (link) Just realize you are making a potential bomb which could hurt you and others. They do make 1, 2 and 3 gallon tanks, I know I guy who had 4-2 gallon tanks hidden in the compartments in the back of his '97 S-10 Blazer. I'm just suprised you can't fit small tanks on the side of the frame without fabbing your own.
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4
Shev is offline   Reply With Quote
Old 01-08-2005, 03:54 PM   #6
bagged72blaz
Got L.E.D.s
I build air headers for the mine contractors I work for, and have been welding for more than 14 years. The only thing I'm good at blowing up is my motor!
Thanks Shane that helps. The pipe I'm using is 4" ID I'll take pictures when I'm done. The reason I ask about gals in air is my tank says 5 gal, but it's muck smaller than a 5 gal bucket.
Old 01-08-2005, 07:12 PM   #7
Slammed67
Progress = 0%
Slammed67's Avatar
Hey, don't mean to change the subject, but didn't you used to go by the screen name "Reumster"?
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 01-09-2005, 01:41 AM   #8
bagged72blaz
Got L.E.D.s
Yes. How's it going? I lost my old e-mail, and forgot my password. Unable to retreave my old user name. I'd like to get my old account back.
I figured 4" X 55"(sort of long) would give me 3 gals. 6" X 2' 3 gals
What about the best place to get compressors Godfathers has 450 Viair for 200.00
Old 01-09-2005, 08:52 PM   #9
Rollie396
someday it will be done!
Rollie396's Avatar
just out of curiosity,what schedule of pipe are you goin with?That and are you gonna use heads on the ends or attempt flat caps?
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 01-10-2005, 03:10 PM   #10
bagged72blaz
Got L.E.D.s
schedule 80 1/4" thick. What I do is cut disks 1/4" thick to the ID of pipe, then cut out holes in the end caps for couplings. Then weld the couplings in on both sides. then sink the end caps into pipe 1/2" to get a good weld. Thats it. But here's my question what can I pour into the tank to seal against rust.
Old 01-13-2005, 02:11 AM   #11
Fat Tom
Once you get it all welded up, I would pour some tremclad into the tank and roll it around real good to ensure good coverage, then pour out whatever is left. That would be my redneck way of sealing it.
69 GMC 2wd 350cid
82 Toyota 4wd, 3.8L V6, 6" lift, 35's, locked and loaded
76 Datsun F10 1.4L ***FOR SALE***
04 Honda Shadow 750
Fat Tom is offline   Reply With Quote
Old 01-13-2005, 03:21 PM   #12
bagged72blaz
Got L.E.D.s
What's tremclad?
Old 01-13-2005, 11:41 PM   #13
Fat Tom
Hmmm... must be a canadian brand, its a rust resistant outdoor paint for metal. A good thick coat of it lasts for years. There must be something similar down there.
69 GMC 2wd 350cid
04 Honda Shadow 750
Old 01-14-2005, 10:35 PM   #14
Rollie396
Rollie396's Avatar
I believe I've heard southernors talk of Rustoleum?I think that would be the equivalent.
'80 LWB 2wd beater
my pics
