Old 11-16-2004, 06:51 PM   #1
JPSAUTO
Support Bearing Help
The pic is of the style on my 69, I want to stay original. The bearing feels ok but the rubber insulator is shot. Is there a supplier for this setup. Or even someone with an NOS piece they'd sell ?????
JPSAUTO is offline   Reply With Quote
Old 11-16-2004, 07:27 PM   #2
CHEVYE
my gas saver
CHEVYE's Avatar
i`m sure you`ve checked but i think you can get one at any parts store. i`ve never bought one but my buddy has a 60`s impala with a carrier bearing and goes through them alot and he gets his there, hope that helps.
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
Old 11-16-2004, 07:36 PM   #3
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
I'm not sure, but when I worked in auto parts, we only had two different carrier bearing assemblies and niether of them looked like that. That one might not be so common.
Cat Fuzz is offline   Reply With Quote
Old 11-16-2004, 07:43 PM   #4
Eddie H.
Eddie H.'s Avatar
My 69 GMC had the same setup. I couldn't find the bearing or rubber anywhere. I finally just got the more common, heavy duty horseshoe type and made a couple of spacers so it would line up properly.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 11-16-2004, 10:59 PM   #5
Maximum Overdrive
December 21, 2012
I have that same setup myself on my 70 3/4 GMC. I never did find a rubber piece myself but I did get the bearing at bearing store. Its lasted 10 times longer than those junk bearings from the parts store.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 11-16-2004, 11:15 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
on the one ton, I was able to get a replacement at advance auto...can't remmeber the brand or P/N though. (same style as shown)
Old 11-17-2004, 11:25 AM   #7
A few 72's
A few 72's's Avatar
My 70 chevy with L-spring rear had the same set up, could get the bearing at Napa but not the rubber. Ended up geting the horseshoe type and a piece of 1"x1" heavy tubing to use as a spacer to get the same drop as the orginal.
A few 72's is offline   Reply With Quote
Old 01-12-2005, 08:31 AM   #8
JPSAUTO
Found It
Thanks for the help, yes Advance has the correct bearing PIONEER #646043, has the correct rubber, the metal dust shields have two rectangular raised areas that have to be trimmed but it works.
