01-11-2005, 09:56 PM | #1 |
Serpintene 'q'
I found a nice serpintene belt set-up off a 93 pick-up to go on my ZZ4, Just need to know if it's a good deal or not. I can get the complete set-up with A/C comp, ALT, PS pump and pullys included for $150.00 is that a good deal?
01-11-2005, 09:57 PM | #2 |
is the tensioner included in that deal?
1969 Chevrolet C-10 Bananamobile. Yes, it's ugly, yes, it's rusty, it's slow too, but no, I'm not trying to show it. |
01-11-2005, 10:38 PM | #3 |
its all about the +6 inches
You'll need a new reverse rotation water pump too.
150 is a bit more than I'd want to pay, but it is probably a decent deal in all reality. (I'm cheap) |
01-11-2005, 10:44 PM | #4 |
yes, it's all still bolted to the engine so i can get all the bolts. So $150 is to much to pay?
01-11-2005, 10:47 PM | #5 |
Watch out for your cornhole !
I'd pay it myself. You get all the stuff in one matched package.
01-11-2005, 10:49 PM | #6 |
my gas saver
i just sold one to putter for $100 and my buddies been giving me hell for doing that, but he`s a board member and getting it in a package deal with an engine. i`d say $150 is a pretty fair price.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
01-11-2005, 10:52 PM | #7 |
no engine just the setup, i want it go on my engine.
01-11-2005, 10:56 PM | #8 |
Windy Corner of a Dirty Street
Not too bad of deal if you get all of the accessories and if the brackets are the aluminum design. If they are the one piece stamped steel design….forget about it….those are junk. When I converted my small block with brackets from a 95’ they cost $50 back in 1996…but did not include the accessories or tensioner.
In addition to the reverse rotation water pump, if you are running an older small block you will need to drill and tap a hole into the passengers side head. Scary! I know, but it can be done. Just remember….do not bolt the brackets to the block…..use studs and nuts to maintain the structural integrity of the bracket design. The later BB used bolts but not early SB.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
01-11-2005, 10:59 PM | #9 |
Thats probably an ok price. Get the water pump, fan (neither of yours will work), all the braces (be sure to take pics of where they go, looking at another setup later on won't necessarily help they are almost all different). Is the a\c compressor R12 or R134a? they are usually marked. Is the alt a CS130 or CS144? either of these will need to be wired different than your run of the mill internal reg alts. Also see if you can get a BB fan shroud (for our years) if you are going to run the fan.
PS get the studs for the braces. Also you can probably get away without drilling the P\S head.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI Last edited by neonlarry; 01-11-2005 at 11:03 PM. |
01-11-2005, 11:21 PM | #10 | |
01-11-2005, 11:32 PM | #11 |
If you have all the braces on, the bracket has plenty of support with ONE bolt missing.
The only hole missing is the upper inside hole. Not really a big deal, I have mine that way right now. I will be changing out engines soon and that one will have acces holes but I didn't see any need to drill the ones I have on there now.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
01-11-2005, 11:43 PM | #12 |
I guess the key word was “properly” fasten.
It is your ride….I guess if your comfortable with that bolt missing then so be it. I know I did not feel comfortable with the brackets not fully fastened as GM engineered it to be.
01-11-2005, 11:55 PM | #13 |
My crate motor came with the serpentine system and a note that some blocks did not have a hole tapped for that one bolt. The note assured me that GM engineers felt that the bolt was not necessary.
01-11-2005, 11:59 PM | #14 |
Well with the AC pump included, plus the alt, ps pump, and the pulleys, I'd say it was a really good deal I looked for a long time for a setup like that for the Z, never could find one below $250, and that was without the accys
71 Chevy C10 "The Rust Bucket" 72 Chevy C10 apart in the garage 02 WS6 T/A Fast Black and bad@$$ 93 Nissan Pathfinder "Emily" Totaled RIP girl 05 Jeep Grand Cherokee-HEMI powered 87 Iroc Z28 305 TPI auto (crying out for an LS1 swap) |
01-12-2005, 12:00 AM | #15 |
my gas saver
mine was on 1974 model heads and never had a problem out of it.
01-12-2005, 12:01 AM | #16 | |
Turn signal switches that fall apart, fuel pumps that last 25,000 miles, plastic distributors that are a throw away item, coils that seperate, rear discs falling apart on the vans, hummer wheels falling off...I can continue, I see all of these at least once a week....except for the hummer, and I don't even work at a dealer...plus 75% of the light duty stuff that comes into our shop are fords....so in the few GM vehicles that come through...for them to all have the same problems a majority of the time must mean something. Heck, whoever came up with the cross fire injection...he was probably shot in the back by a mechanic....and whomever thought up the CPI injection system...I'll bet he is making a killing off all the parts sold....esp since if you just need an injector, you buy the whole thing...if you need a pressure regulator....again, the whole thing. Just becouse the good general made it so, does not mean it was a good idea, nor 100% needed. In the 67 - 72 trucks....many don't have the one lower bolt holding in the heater box....but I'm willing to bet a punch in the gut that no one has suffered any cold air leaks if all the other bolts were tightened. But GM says it needs it...so it must be true. |
01-12-2005, 01:21 AM | #17 | |
Lovin' Life in Miss.!
The truck... you hear that? No really, you did hear that?!!! |
01-12-2005, 01:21 AM | #18 |
I have the serpentine belt system on a Vortec 350 and I love it.
'72 Chevy Cheyenne Super, '56 Chevy Bel Air,'56 Chevy Nomad, '61 Chevy Impala, '64 Cadillac Fleetwood, 1966 Thunderbird Convertible |
01-12-2005, 11:01 AM | #19 |
I guess the verdict is in…..If you don’t want to drill the hole, you don’t have to.
It only takes about 10 minutes to drill and tap the hole. Cheap insurance…providing a person takes their time drilling the hole and does not drill into a water jacket.
01-12-2005, 11:37 AM | #20 | |
