01-13-2005, 12:38 AM | #1 |
got some parts together!!!!
finally i am seeing some progress and i am getting exited to start working on this truck. heres what ive got so far. DJM 3" dropped spindles, rotors, calipers, wheel bearings, pads, control arms, balljoints, bags, plate and cup kit, taillight fillers, and handle flip kit. all that im waiting for to get the front suspension and bags in are the new bushings. hopefully they will be here tomorrow so that i can get this party goin! also check out the junk yard control arms. i just got them back from the sandblaster so i threw some quick primer on them. i still gotta take the ball joints and bushings out of three of em and get them painted so i better get on it because the bushings will be here tomorrow.
01-13-2005, 09:54 AM | #3 |
Awesome!! Bet you are just anxious to get started.
So is your truck still a dually or has the transformation been done yet?? |
01-13-2005, 12:39 PM | #4 |
What truck are you putting this stuff on?
What are the details on the brakes? Are you still going to get that truck in your avatar?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
01-13-2005, 07:36 PM | #5 |
Project92 SWB stepside
Better paint the spindle and any other bare metal. It will rust quick!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
01-13-2005, 10:02 PM | #6 | |
Are you putting all the parts on the 88 CC in your sig? If so, you are converting from 1T to 1/2T? Will bags still give you the load capacity (1 ton) as the spring set-up? I like the idea of what your doing, CC SWB, and was wondering if you wouldn't get a better ride with 1/2 ton suspension. Do the bags give you a better ride than the springs? Hope it all works out!
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
01-14-2005, 12:42 AM | #7 |
ok heres the deal. the truck in my avatar is what i hope mine to look like only white. all of these parts are going on my black 88 cc dually. it is exactly like i got it ALL STOCK!! the only reason im going with 1/2 ton suspension is so that i #1 will have lots more wheel options and #2 the rearend i have is a shortened 9" with the 5 on 5 patern. as far as the 1/2 ton holding up to the truck, i dont think it will be a problem. because the bags are 3600#ers. i think the only thing that may be an issue is the ball joints. ill keep posting as i get this going. my truck is below
01-14-2005, 12:48 AM | #8 | |
maybe i am just cluless, but i had not thought of painting them. thanks for the tip. i dont know what i was thinking. |
01-14-2005, 10:56 AM | #9 |
Looks awesome its always fun to get new parts it always makes you have a feeling to work more on what you usally procrastinate.
01-15-2005, 10:06 AM | #10 |
couldnt you just throw a 1/2 ton crossmember under the front?
www.krazykustumzkc.com |
01-15-2005, 12:09 PM | #11 |
On the earlier 67-72's I"ve heard that dually, 1 ton, 3/4 ton frames are taller vs. the 1/2 ton frames. Is this different w/the 73-87's? Or maybe it was just the 73-87's that were taller??? I know I heard something along those lines.
Anyone know for sure?
01-15-2005, 06:24 PM | #12 | ||
