I am in the midle of my front suspension rebuild and need some tips on installing the lower rubber triangle shaped bumpstops.
Is there a trick or any helpful hints are greatly appreciated.
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Put them in the microwave for about 10-15 seconds then run outside and pop them in. The heat makes them pliable.
I tried the microwave thing & it didn't work for me. I tried boiling water as well w/no luck.
What I wound up doing was drill an access hole (I had a 5/8" hole-saw handy)in the front of the bump-stop 'mount' so that I could grab the rubber & help pull it into place while pushing/wedging it in from on top. I also used a little dish washing soap to make things a little slippery. It took longer to drill the hole than pull the snubber into place (& it didn't take long to drill the hole).
thanks for the replies
Dish soap and alot of wiggling and forcing them into to slot.
Alex 1971 Lil' Red 350 SBC 700R4 |
I sprayed mine down with silicone, popped one side in, then used a flat prybar (could use a big screwdriver) and pushed the other side down into the channel. Good luck however you try to do it!!
I just did mine this week. I got some liquid laundry soap...gooped a bit on the triagle shape and pushed it straight down. Went in real easy. Mine were brand new so they were already pliable. My lower A-arms are also powder coated so that might have helped. They are real shinny and slick.
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
If you already have the silicone (tube or spray), it would be a little better since it's not water based, is harmless to rubber, and is more slippery.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
