Back From The Track!!
Hmmph..didn't run QUITE to what I was expecting, but then again, I basically had to be like a top fuel dragster, and not hit the throttle till half track. I made four passes of the day...
First Pass: Feathered it till half track, where I proceeded to hammer it and get the truck's back end loose, so I backed out of it. Second Pass: Tried manually shifting, but it never got traction, so I went down the entire quarter mile almost, in 1st gear, with the tach floating around 4500, just trying to feather the rear tire to get it to hook Third Pass: Left it in drive, feathered it a bit better, caught a 16.0 @ 86mph. This is basically STILL not even hitting the gas till half track. The 60' on this run was a 2.55 Fourth Pass: Did the same as the previous pass, but got on the gas a little too soon, so the rear end got loose and I backed out of it. I think I DEFINATELY need some stickies. Obviously, when I got the best traction on the third pass, I was able to at least GET a mph that wasn't ENTIRELY bad. I'm going to go again when I get some stickies, and shoot for a mid 14 @ 90mph+. If someone wants to host the video of the third pass, I'll get it edited. |
The track must not have been prepped too good. My 14.51@ 91.01 came on 255/60/15 Firestone Firehawk Indy 500's. Those tires hooked like you would not believe. The 275/60/15 I have now do not hook anywhere near how those did. My next purchase will be some 26 X 10.5 X 15 ET Streets.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
BeWarE tHe eViL CrAnkTOe!
So your saying that you can hit the throttle from 40-60 mph on the street and just spin the tires at will? Tracks are much stickier than that. And I have never heard of anyone not giving it full throttle at the track.....especially not doing it until 600-700 feet out..I mean whats the point? Unless your making like 1000 rwhp that WILL NOT be an issue. Hell my buddy with the 841rwhp supra ran 11.3's @131 spinning literally all the way down the track.
but see the thing is, your 86 mph trap shows your time is about right. Lemme guess....your 60' was about a 2.4 right? The reason I guess that is because my GAGT used to run 16.0@86 all day long spinning mad out of the hole running 2.4 60's. Im telling you, it takes a lot to get these trucks into the 13's or near it, they are heavy and shaped like bricks mang. ![]()
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods ![]() www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
Garage Queen Material
my best time was with my 2.73 gears
15.09@94mph 2.4 60' time my best time out of the 2 runs with my new gears and posi and tires is: 15.97@91mph 2.58 60' time that last run was with the engine problems and when the rocker arm was about to pop off. it spun and then bogged down bad. the run i had after that was decent?? 16.9@84mph 2.58 60' time spinning halfway down the track full throttle. it quit spinning when i let off the gas... thats the run that the rocker arm DID pop off.. i need tires too. but i wont get them until i get a new built tranny |
Funny thing is, on the last run when I couldn't get traction, I ran a 16.6@83mph, so obviously the traction does make the truck run faster. Strangely enough, on the street, it won't spin them at will, but yesterday at the track, it DID spin like a mofo
#6 | ||
#7 | |
What I meant on getting traction..for my cars at least, when I get a better 60', my mph increases at the top end... |
#8 | |
yeller
I think there are three things going on here... 1. Your tires suck. 2. The track sucked. 3. Is your TG on the truck yet? If not, what were you thinking!? The extra weight will only help, and the lack of weight (if it is still off), will only hurt you.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 01-16-2005 at 09:32 PM. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Tim,... what happened to getting your truck painted? Did I miss something,... or did you do that already?
Right turn Clyde
Those are the numbers Ive ran. I doubt to see much lower times out of it with out some more engine parts or slicks. We have pretty much the same engine specs. Just very mild small block, even though it may feel a lot different on the street. The track will make you humble again from what you may think you will run and what you are running. Those aren't bad times at all but I really don't see 14.5 out of it as it is engine wise.
I would get some 15in rims and some slicks mounted if you are going to get them. With your wheel and tire combo the lower profile tires aren't doing to much for your traction. With the 15's they are cheaper and you can get more sidewall on the tires that will help with the traction.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
#11 | |
california fill
how much air pressure are you running in the tires? if its above 30, that aint helping with the tire spin... for S&G's Id run about 16-18 or less if you're brave for a better hook up.. put a couple bags of concrete in the bed, over the axles too.. a couple hundred pounds aint gonna hurt your rolling resistance much, and its gonna help out with traction a LOT...
pc |
Get some traction bars. Makes for bit of a rougher ride, but they do help. At least mine do. G hooked me up on those.
#14 | |
#15 |
My TG is still off, because I don't have one. I'm looking into getting another one though. I thought the fuel cell being directly above the axle would help with traction, but I guess not really.
Definately would like to get a set of Cal Trac's made for my truck. But I definately think with better tires, and maybe a little tweaking of the carb (Might need bigger jets, gotta check air/fuel ratio) might yield me a mid 14. Funny thing is, my friend has a 73 Nova and he ran a 15.0@94 at the track, and from a 40mph roll on the street, I can hang right with him... |
#16 |
Also....Typically when you lower your 60ft your mph at the end will drop....MOST of the time, but not always.
#18 |
I wonder if those would work with a flip kit
![]() Not too bad though, at $100... |
#19 |
from the looks of it, i think its only for trucks without a flip kit, but im shure you could make it fit with the flip kit some how
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
#20 | |
#21 |
Time for a 4-link!
