Old 01-17-2005, 04:58 PM   #1
beagler
Need Advice for Patch Panel Replacment
Hey
I'm getting ready to replace my inner and outter rockers as well as my cab floor supports (front and back) What I was wanting to know form you guys who have done this is are there anything that I should watch out for. I Plan on replacing the floor at a later date should I wait to put the rockers and stuff in when I do the floors pans? I haven't did anything like this before so just let me know any snags that you guys ran in to.
Thanks a bunch guys
Russ
'71 GMC 350 bored, cam'd, straight pipes
LOOKING FOR A 4x4
redz 1970 K5
"Time has stopped for our classic trucks, and as such maintain nostalgia and simplicity of the vehicles and of an era passed."
beagler is offline   Reply With Quote
Old 01-17-2005, 05:09 PM   #2
StingRay
StingRay's Avatar
Have a look at this thread. It's pretty extensive. Look through the paint and body board in general as there is alot of good stuff in there written by the Pro's that frequent the board.
http://67-72chevytrucks.com/vboard/s...8&page=1&pp=25
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 01-17-2005, 05:21 PM   #3
beagler
Sweet thanks StingRay. Any other advice? Thanks guys
LOOKING FOR A 4x4
redz 1970 K5
Old 01-17-2005, 06:32 PM   #4
pierce
pierce's Avatar
Alright!...from Cincy! Welcome! It might be easier to fix the floors first after taking off the old supports to see how much repair is needed especially around the body mounts in rust city.
69 GMC 1 Ton Longhorn
37 Chevy Coupe
pierce is offline   Reply With Quote
Old 01-18-2005, 03:01 PM   #5
beagler
kool thanks pierce.
LOOKING FOR A 4x4
redz 1970 K5
Old 01-18-2005, 03:19 PM   #6
avejoe
Custer had a plan too.
avejoe's Avatar
I tried this for the first time last Spring. My advice:
1. Practice welding. Once you think you have it down, practice more. The guys on TV make it look way easier than it is. Why don't they show us all the time they take on grinding?
2. Figure the time it will take. Multiply that time by 5.
3. If you want a really good result, multilpy the product of #2 by 3.
4. Have lots and lots of patience, space, light, and patience.
5. Have patience.
6. Did I mention to be patient?
7. Buy way more sanding and cutting disks than you think you will need.
8. Don't weld in tennis shoes so little balls of molten metal can fall in the opening of your shoe, put holes in your socks, and burn the sh*t out of your ankle.
Good luck.
72 K15 GMC (aka Big White)
Performance Rockers, Cab Corners, and Floors
Fossil Fuel Glutton
Neighborhood Nuisance
98 BMW 540i for Speed (Sold )
05 Subaru Outback for mileage
avejoe is offline   Reply With Quote
Old 01-18-2005, 06:35 PM   #7
72CSTC5
72CSTC5's Avatar
Well make darn sure you brace your cab very well before you go start cutting out the rockers, floors, and cab corners. By bracing I mean a brace between the door hinges and door striker plates. Brace from side to side too if you can. Measure twice, cut once as they say. Good luck.
72CSTC5 is offline   Reply With Quote
Old 01-18-2005, 06:57 PM   #8
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
hey beagler. i just finished my cab of death. i had to replace the floors, the inner & outer rockers, cab supports, cab corners and i had to fab pieces of the support that goes across the back of the cab & i had to fab lots of floor from under the tank. i had all triplus & tabco pieces & they were fine. yes, brace your cab!, (mine was so rotted it had spread & i had to use a piece of threaded rod to pull it back in), buy a good welder that has a infinite amperage adjustment (i have a lincoln sp-135plus), avejoe is right too - buy cutoff wheels by the dozen, practice your guts out welding. & learn to like metal grindings in your hair too! lol
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 01-18-2005, 07:41 PM   #9
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Good luck.
Yeah, i have a hard time learning this one. I keep on doing it
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 01-18-2005, 08:28 PM   #10
Vince Putt
Hippy
I was a fraid to admit it but I did the molten metal down the shoe thing too! Man that was painful!!!
Vince Putt is offline   Reply With Quote
Old 01-18-2005, 09:03 PM   #11
ebfabman
Once, many moons ago, when I was a teenager, I worked at a car care center as the exhaust installer, I did the ol pop thing with the cutting torch. A glob of molten metal about 3/8ths of an inch in diameter went down my uniform shirt, made a nice burn mark on my neck, down my chest, into my pants, around my nard, past the twins, down my leg, into my shoe, and burned a hell of a hole in my foot and shoe. I learned to dance that day and proper use of (and respect for) a cutting torch.
ebfabman is offline   Reply With Quote
Old 01-18-2005, 11:09 PM   #12
beagler
Good thing I don't have any hair! thats just one of the many reasons I shave my head. lol
THANK YOU TO ALL OF YOU !!!!!!!
This really helps me out. Oh yeah I'll deffinatly use boots. lol
LOOKING FOR A 4x4
redz 1970 K5
Old 01-18-2005, 11:35 PM   #13
Dean23
68cst_ss490
Dean23's Avatar
I had to do floor pans cab corners, mounts and rockers on my 68 i started by bracing the cab up then cutting out the rockers and floor etc
drivers floor
passenger
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 01-19-2005, 01:26 PM   #14
beagler
how would you guys suggest I brase the cab. any pics I saw the one brace in your pic dean but what about the other side? nother question what about the floor supports? I was going to put those in my truck any pictures of those being put in? were they go exactly? These are the ones that I was going to buy. any suggestions? thanks again guys
Front Support
http://manestruckparts.netstorekeepe...Category_ID=18
Rear Support
LOOKING FOR A 4x4
redz 1970 K5
