Old 01-19-2005, 03:14 PM   #1
ACES
Life is a gamble
ACES's Avatar
Body Mount Bolts
Are the Body Mount bolts welded in from the factory?
or did I just get very unlucky with the previous owner?
Mine are welded in at the bolt head to the floor in the recessed part.
I'm replacing the body mounts today and I'm having to grind it out with a dremel.
1970 Orange CST C-10 w/350, posi, Longbed
The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine.
-- Ralph Waldo Emerson
ACES is offline   Reply With Quote
Old 01-19-2005, 03:34 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
I've seen some that were and some that weren't. I suspect what you have is factory
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 01-19-2005, 03:56 PM   #3
Custom 68
Custom 68's Avatar
yep mine were also welded from the factory
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 01-19-2005, 04:00 PM   #4
ACES
Life is a gamble
ACES's Avatar
This sucks
I'm having one heck of a time removing the rubber thats still between the body and the frame.
Old 01-19-2005, 04:08 PM   #5
ACES
Life is a gamble
ACES's Avatar
I think its obvious at this point that I am going about this all Wrong.
I have completely underestimated this project.
I figured that I would just loosen the bolt on a corner, then jack that corner up, then remove rubber and replace with new rubber. No big deal right?
WRONG. This sucks
Why didn't you guys warn me?
Old 01-19-2005, 04:23 PM   #6
OLDCHEV4X4
OLDCHEV4X4's Avatar
after you figure out the first one the rest will go easyer. Mine were welded in too, only i did my blazer and it has 8 mounts.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 01-19-2005, 04:27 PM   #7
ACES
Life is a gamble
ACES's Avatar
You my friend are an Iron Man
Please share any tips that you have!!
Old 01-19-2005, 04:28 PM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
I must be lucky, my 67 and 69 were just bolted. You'll get it bro, and its definately worth it. I could feel the difference in the ride.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-19-2005, 05:36 PM   #9
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
Have you got an air chisel you could pop the weld with? Just thinking out loud.....Jerry
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 01-19-2005, 06:25 PM   #10
ACES
Life is a gamble
ACES's Avatar
Thanks for the replies guys. I got the drivers side front and rear done. I'm going to relax a bit and tackle the other side tomorrow.
Air Chisel actually sounds like a good idea.
