Old 01-19-2005, 02:37 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
? for you Transmission Guys
My 350 torque converter would not bolt up to my 454 flexplate so I drilled new holes.
My Question is
Can I put a 400 torque converter in a 350 trans so it will bolt right up ???
If so would there be a differance in stall speed, Good or Bad??/
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 01-19-2005, 05:02 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Yes you can install a TH400 converter into a TH350, that is how I hooked up a TH350 to my caddy big block.
As for stall...I've been told by some, that it would increase stall...and by others that it would DEcrease stall....NFC, I know it moves, and doesn't do anything stupid.
I would highly consider getting another 454 flexplate. Really isn't a good idea puttin holes in there.
Old 01-19-2005, 05:25 PM   #3
1970 CST Short Wide
Senior Moment
Thats why I'm askin, I didnt like drilling the holes either but it was right at the time if you know what I mean. I really like to know what if any differance there is in the Stall. The engines coming back out for another reason and I'd like to do it right.
Pittsburg Ca
94565
Old 01-19-2005, 08:24 PM   #4
Longhorn Man
If there is, I highly boubt it's noticable. Like I said, mine feels right. A stock converter, and it feels...stock. When i floor it, it flashes a little stall, but it'll idle across the parking lot no problem.
Old 01-19-2005, 08:39 PM   #5
Super Duck
Chevy Nuttttt
Super Duck's Avatar
A th400 converter will be fine I ran one on my th350 in my k5. as for stall a converter will stall at a lower rpm with a sb than a bb. find your self a Trans Star store. they are who the trans guys get their parts from.
67' Chev swb step side
69' SS elky
03' Chev ext cab 4X4
hey who lernt me to spell
is there anything else?
Super Duck is offline   Reply With Quote
Old 01-19-2005, 08:53 PM   #6
racer face
hi guys I was just reading your thread and unless you know your holes
are dead even your going to get a vibration which will do all kinds of bad
things. so I'd get that out a.s.a.p.
tork coverters stall at what ever r.p.m they were made at, stocks are like
1000 to 1200 r.p.m or so.I wouldn't swear to this but most start to roll just off idle. Now you can always buy a true stall coverter from sumit or jegs
but don't go to high into the r.p.m's because if your town cops are like the
ones here in wellington ohio just going down the street will get you a ticket!
A friend of mine has a pro street nova with a 3000 r.p.m stall(more strip than street) and ever time it shifts it churps the tires. hope this helps if not, oh well.
racer face is offline   Reply With Quote
Old 01-19-2005, 09:36 PM   #7
cdyblu
cdyblu's Avatar
Stall speed
Stall speed on any tourgue converter is strictly a function of the tourque put into the converter. standard converters (stock) are designed to stall at about 1000 to 1200 rpm behind a stock engine. Higher stall converters are designed to move the stall speed up in rpm range as more tourque is applied to the converter. This allows you to take better advantage of the "fat" part of the engines tourque curve, which will result in better launchs.
Replace that drilled flex plate asap, you can get an sfi approved flexplate for under $50
cdyblu is offline   Reply With Quote
Old 01-19-2005, 10:55 PM   #8
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Yup all cops are alike,I used to run a 9'" converter with a 350 turbo and 4.56 gears.Sounded like I was scalding the tires just to get the car moving.Got lots of tickets because of it.
As far as the stall of the 400 converter in a 350,you might get a couple hundered RPM,nothing to write home about,and if you have any power at all you prolly won't even notice it.
I do agree,swap that flexplate ASAP.better safe than sorry.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 01-20-2005, 12:46 PM   #9
1970 CST Short Wide
Senior Moment
Thanks guy
I'll be heading down to my Tranny Guy to get the right converter
Pittsburg Ca
94565
