Old 01-20-2005, 02:21 PM   #1
Smokin72on20s
Ebay Junky
Smokin72on20s's Avatar
How big is your fuel cell?
how many gallons does your truck take? For a daily driver, what is the average sized tank that you should have? also, will this tank work with a 72 its measurements are 20"wide X 18" long X 10" Deep.
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain..
1983 Chevy c10 swb 2wd - possible 350tbi supercharged...
Smokin72on20s is offline   Reply With Quote
Old 01-20-2005, 04:50 PM   #2
67chevemall
67chevemall's Avatar
I think I have a 18Gal
Sounds like the same dim's you posted!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 01-20-2005, 05:17 PM   #3
Smokin72on20s
Ebay Junky
sorry, i forgot to mention that the tank would be going between the frame rails under my bed.
Old 01-20-2005, 05:24 PM   #4
OhioDan
OhioDan's Avatar
Thumbs up
My gas tank is for a 78 Chevy van. Holds 31 gallons. Had to make my own hangers and brackets. Fuel hose connects up right in front of the rear spring hanger. Hangs kinda low, but I ain't plannin on goin off road with it. Oh yea, it fits right between the frame rails also.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 01-21-2005, 01:43 AM   #5
Smokin72on20s
Ebay Junky
do you think a 15gal. tank would be sufficient?
Old 01-21-2005, 02:08 AM   #6
71swb4x4
71swb4x4's Avatar
I think my fuel cell is a bit bigger than yours. Mine fit fine. Mine is 20 gallons and there is no way I would go smaller.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-21-2005, 06:53 AM   #7
modifiedGMC
fuel cell
You've heard "size don't matter"? well when it's a fuel tank is DOES matter! I relocated mine to the rear also. I wanted to keep enough room to install a receiver hitch. I used a tank from a chevy Luv but modified it slightly (it hung too low) well when I started driving the truck and filled it up the first time it only held about 8 1/2 gallons! I definitely will change that because 8 1/2 gal doesn't last long. I relocated the filler behind the left side marker light after removing a portion inside the bed.
modifiedGMC is offline   Reply With Quote
Old 01-21-2005, 09:10 AM   #8
Peregrine
Peregrine's Avatar
Not big enough! It's around 12 gallons
Brian
72 C10 longbed 350/th400
Let the world change you and you will change the world.
Peregrine is offline   Reply With Quote
Old 01-21-2005, 10:23 AM   #9
Huck
Huck's Avatar
Blazer/Burb tanks are like 20-21 Gallons and they fit perfect as the trucks and Blazer/burbs use the same rear frame dimensions. Many of our trucks were fitted with saddle tanks by dealers or aftermarket due to the fuel consumption of these gas hogs. A 20 Gallon tank is ok but a 25-30 is nicer for trips etc. All depends on what you are trying to accomplish.
Huck is offline   Reply With Quote
Old 01-21-2005, 10:38 AM   #10
GreyHoundSteve
Mine is 15 gallons and it tucks under the truck nicely.
GreyHoundSteve is offline   Reply With Quote
