Old 01-22-2005, 07:58 PM   #1
jfrank133
AUSTIN TX
jfrank133's Avatar
Question about removing the heads
Ok, how can i start this, I have been trying to remove both heads from the motor for the past 2 hours, i loosen up the 8 bolts inside and the 8 bolts outside, and I tried to remove the heads but it just wont budge, is there something that im missing, i left the rockers and rods in place, do I have to remove them two before removing the heads. by the way i have a 87 chevy sctotsdale with a 305 engine. please help. thanks
jfrank133 is offline   Reply With Quote
Old 01-22-2005, 08:09 PM   #2
dons454s
dons454s's Avatar
If you have all the bolts out they just need pryed loose. It will take some thing healthy like a tire iron large pry bar..
dons454s is offline   Reply With Quote
Old 01-22-2005, 08:12 PM   #3
rage'nrat638
rage'nrat638's Avatar
if you have all the bolts out...they should come off.....
use a pry bar.....in the front and pry up.....they might be stuck real good....
you do have the exhaust manifolds off correct?
mark
rage'nrat638 is offline   Reply With Quote
Old 01-22-2005, 08:21 PM   #4
dwaite72lnghrn
I pretty sure it's 9 under the valve cover and 8 along the exhaust manifold.
I always pull the rods so they don't get bent when I pull the heads. It will also make it easier to put back in.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 01-22-2005, 08:27 PM   #5
jfrank133
AUSTIN TX
jfrank133's Avatar
yes the manifolds are off, but i only counted 8 inside the valve cover and 8 outside.
Old 01-22-2005, 08:29 PM   #6
low 84
low 84's Avatar
there are 17 bolts for each head so you missed one somewhere
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 01-22-2005, 08:32 PM   #7
jfrank133
AUSTIN TX
jfrank133's Avatar
ok then i missed one from the inside, it has to be somewhere inside. I will continue to look thanks very much.
Old 01-23-2005, 12:15 AM   #8
784X4GUY
Did someone say MUD?
784X4GUY's Avatar
Heck ive even used a small flat head screwdriver to pop them up and break the seal. Good luck man...Later Mike
Im in the market guys...so keep ya eyes peeled
Mini trucks are for guys who cant get it up!
784X4GUY is offline   Reply With Quote
Old 01-23-2005, 01:01 AM   #9
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Ive been there!!! Prying and prying and OH $hit that why its not coming off.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
