01-15-2005, 08:21 PM | #1 |
Need Rear Suspension Parts
I Am In Need Of The Front Brackets/pearches For The Rear Leaf Springs On A 1970 4 X 4 , Mine Are Rusted And Cant Find Any. Lmc Sells 73-later But Not 67-72. If Anyone Has A Set Not Still Rivited To The Frame That They Wish To Sell I Would Be A Happy Man. Thanks For Your Support!!!!!!!
The Garage 1970 stepside 4 x 4 2005 caddy deville 1998 dodge 2500 diesel 2006 h-d street glide 1948 h-d rigid |
01-23-2005, 11:07 AM | #2 |
somebody has to know where i can score these items. please........ i really need them
01-23-2005, 11:55 AM | #3 |
I Think I Have Some ,they Were Off A 72 3/4 Ton 2wd I Don't Know If 4wd And 2wd Are The Same . I Have All 4 For The Rear Springs. I Believe The Were 2 1/4 Spring Width.
01-23-2005, 01:38 PM | #4 |
Senior Moment
I have a set from a 2 wheel drive also, 1/2 ton still on frame.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
01-23-2005, 02:46 PM | #5 |
user # 2756
The 2wds will not hang down as far as the 4wds, you'd loose height. I'll be removing mine here in about 2 months to install some from a 72. The 71s and up drop further than the 70 and earlier. I've promised them to someone else but he might not be able to use them. I can let you know in a couple days.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
01-23-2005, 04:47 PM | #6 | |
01-23-2005, 04:49 PM | #7 | |
