Old 01-23-2005, 07:21 PM   #1
beautimus
beautimus's Avatar
posi rear questions
how do you tell if a posi is in good shape (clutches and stuff)
its a 12 bolt , 1970 model.
also how do you clean out all the old gunk inside to put in fresh lube without messing stuff up? any ideas?
Tony
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 01-23-2005, 08:37 PM   #2
Sweet72
Sweet72's Avatar
Parts cleaner or kerosene in a spray bottle and a parts brush for the clean up. I wouldn't spray the clutches too much. If memory serves me... you can check your clutches for wear with both rear wheels off the ground, turn one wheel and have a helper hold a little resistance on the other wheel... both wheels should turn the same direction.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 01-24-2005, 12:36 AM   #3
me3
hart
a old pump up weed sprayer works great and fairly cheap
me3 is offline   Reply With Quote
