Old 04-11-2002, 03:48 PM   #1
alberocks
Question light switch removal
How in the heck do you remove the light switch so I can remove the instrument cluster?
alberocks is offline   Reply With Quote
Old 04-11-2002, 03:52 PM   #2
Nichboy
Post
Reach up under the dash to the top of the light switch, there is a spring loaded button on top of the switch, you have to push it down and pull the switch button out.
1971 Chevy SWB
Oklahoma City, Oklahoma
Nichboy is offline   Reply With Quote
Old 04-11-2002, 03:55 PM   #3
barn9
Half a bubble off!
barn9's Avatar
Post
Reach up in behind the dash and feel for a release button on top of the swith housing. This button will release the stem and knob so that you can pull that out of the way, and the rest you will see.
------------------[*]'71 Cheyenne, 402BB[*]Winfield, KS[*] http://barn9.freeservers.com[*] steer50@hotmail.com
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 04-11-2002, 04:04 PM   #4
704x4
Post
don't forget that the lights will be in the on position
either unplug the switch or disconnect the battery
70 3/4 ton 4x4
FOR SALE
Greene, IA
704x4 is offline   Reply With Quote
Old 04-11-2002, 04:32 PM   #5
Andy4639
Old member
Andy4639's Avatar
Cool
If you turn the knob all the way to the left it will unscrew itself, but it was glued from the factory, I have never done this reaching up under the dash deal. It does work I'm sure but a lot of trouble to get to. I also put new knobs on my 71 that have set screw in them also though.
Andy
71's Are for ever!!! or 67,68,69,70,72 http://geocities.com/chevy71tpi/main.html
http://www.picturetrail.com/Andy4639
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
