01-26-2005, 03:27 PM | #1 |
73 a- arms on a 72
I have a 1972 chevy c-10 half ton and i recently saw an item on ebay and it's a 4" drop kit for the front but it states that its for a 1973-1987 chevy half ton and i was wondering if theres any way that this can be made to fit under my 1972 which by the way has stock front disk brakes .Thank You.
01-26-2005, 04:21 PM | #2 |
to get the 4 inch drop they might be using a 3 inch drop spindle.... which would have different balljoints. 1 inch spring. = 4
01-26-2005, 04:37 PM | #3 |
...and 73up outer tie rod ends, these will fit the 71-72 sleeve but not the 67-70 sleeves...
You may need to check the width of your front disc too... I'm not sure, but i think some are 1'' and others are 1.25"(?) Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
01-27-2005, 02:42 AM | #4 |
thank you very much. taht really lights the way.
01-27-2005, 08:19 AM | #5 |
Watch out for your cornhole !
If it involves a spindle, the upper ball joints are different for 73 and newer. Lowers are the same though.
01-27-2005, 09:20 AM | #6 | |
Happy to be here
