Old 01-28-2005, 09:56 PM   #1
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
speedo calculator???
Can some one direct me to a site....or calculate this for me.
31 inch tall tires (as sitting with the weight on them)
4.10/4.11 gears. (can never rememver which it is....C/30 HO72 rear)
Auto tranny w/o lock up nor overdrive.
What'll my 65 MPH RPM's be at?
Can anyone tell me where to get non chevy Th350 gears? I was rather shocked to see they were not the same as chevy.
That sucker is readin 60 - 70 when I am only goin 40 - 50, and it is racking up some miles just putting around the lot at work.
Old 01-28-2005, 10:02 PM   #2
69 Short Fleet
You might call a local shop with a dyno, I know my race bike mechanic in Calgary has one and dyno results were used as evidence in court as the rider (GSXR bike) disputed the police's radar gun. Just a thought, Doug
69 Short Fleet is offline   Reply With Quote
Old 01-28-2005, 10:12 PM   #3
Z28Owner
Z28Owner's Avatar
Right at 2900 rpms http://www.700r4.com/sitemap.shtml
1971 LWB Chevy C-10
350/350 3:42 eaton
Z28Owner is offline   Reply With Quote
Old 01-28-2005, 10:20 PM   #4
Longhorn Man
Sweet...that's right about what I was expecting.
I guess that isn't too bad.
Thanks for the link too!
Old 01-28-2005, 11:11 PM   #5
COBRO
Active Member
Talking
Longhorn Man the 2900rpm figure is correct but thats figured with total lockup with a clutch or a locking converter,I just went through this same game when I switched a th400 for the stick in my 72. I was turning appox.300 more rpm at the same speed than before because of the slippage in the non lockup converter I used. You can check out the thread "more rpms" on page two. HTH:::::::::::COBRO
COBRO is offline   Reply With Quote
Old 01-28-2005, 11:22 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Originally Posted by Z28Owner
IS A TH350 A 1:1 RATIO TRANNY
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-28-2005, 11:25 PM   #7
Longhorn Man
Yeah, TH350 is 1 to 1.
I was kinda figuring that might be with no slippage. You're getting 300 RPM slippage at highway speed? That seems exsesive. I've never seen more than 200 or so. I have a TH400 converter in my Th350, so it'll either slip a bit more, or a bit less...I am pretty sure it is the latter.
Old 01-28-2005, 11:27 PM   #8
jhow66
jhow66's Avatar
In high gear--yes.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-28-2005, 11:31 PM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
"GQ"S MOTOR IS A BUILT 1970 LT1 CAMARO BLOCK W/ FORGED
EVERYTHING, 3 DEGREE VALVE JOB, HEADS HOGGED OUT, ETC...
ACCORDING TO THE PO, CHART, TIRES & MY GEARS I COULD GO
OVER 200 MPH EASY WITHOUT EVEN PUSHING MY MOTOR.
OF COURSE, DRAG ON A BLAZER BODY CHANGES ALL OF THAT
Old 01-28-2005, 11:39 PM   #10
Longhorn Man
Whats your gears & tire size, what tranny, and what's the redline?
Old 01-28-2005, 11:50 PM   #11
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
GEARS - STOCK 3:08'S OR 3:07'S
TIRE SIZE - 35 X 12.5 X 15 BFG'S (8" RIM)
TRANSMISSION - TH350 W/ NP205
REDLINE - BETWEEN 6500 AND 7000
Old 01-29-2005, 07:07 AM   #12
Longhorn Man
at about 6000 RPM, your blazer would be doing a theoretical 200 MPH.
This is my old beater with 3.07's and 28 inch tall tires and a non lock up TH350.
Old 01-29-2005, 07:16 AM   #13
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
EXCEPT FOR THAT BIG @SS BODY CAUSING WIND DRAG
Old 01-29-2005, 11:05 AM   #14
bgood
bgood's Avatar
I like to use these calculators
http://www.tciauto.com/tech_info/calculators.htm
just for a second opinion i guess
1967 C10 Short,Step
283\1460 Holley HEI Ign.
Borg Warner T56 6 Speed!
A-1 Electric life pwr windows
PS,PB,Tilt
275\60R'S on Alum Mags all around
Vintage Air A\C
Grey cloth Buckets
bgood is offline   Reply With Quote
Old 01-29-2005, 11:08 AM   #15
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Originally Posted by bgood
NEAT SITE
Old 01-29-2005, 06:01 PM   #16
Longhorn Man
Remember though, in theory...comunism works.
Old 01-29-2005, 07:55 PM   #17
69 longhorn
Andy, does your BOP turbo have the 1 1/2" speedo gears , like found in the 400 turbos? here is a slick site, for figuring speedo gears... http://www.novaresource.org/speedo.htm 69 L
69 longhorn is offline   Reply With Quote
Old 01-29-2005, 08:18 PM   #18
Longhorn Man
Al, 1 1/2 inch gears does sound about right...I didn't know the 400 was like that...good news I guess huh.
Thanks man.
Old 01-29-2005, 08:25 PM   #19
69 longhorn
Im not real familiar with the small bop turbo, but have been into the 400, in both chevy & bop style. they both take the same speedo gear setup. if you do have the 1 1/2" gears, the Nova site will get you dialed in on the gears, as well as working for the 3/4 " dia speedo gears.....that covers it from any Gm stick (early), to the Richmond I am running.... 350 turbo (chevy), & I think powerglide 69 L
