Old 01-29-2005, 08:11 PM   #1
69 longhorn
The old longhorn is gettin a gear change
Yup, as much fun as those 4.10's are, they are coming out in favor of the original 3.40 gear that were in the 12 bolt. i have a new pinion yolk for 1350 U joints, & also plan to upgrade the drive shaft, & add a set of Moser axles......lookin for tha "freeway flyer" 69L
69 longhorn is offline   Reply With Quote
Old 01-29-2005, 09:10 PM   #2
1969 GMC
1969 GMC's Avatar
sweet...did it originally have a big block?
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 01-29-2005, 09:43 PM   #3
69 longhorn
No, it was originally a 350 powered truck.....it has run 2 455 Olds mills, & 1 425 cad , & a couple sb chevs over the last 20 yrs tho.... 69L
Old 01-29-2005, 11:52 PM   #4
kwmech
In my experience big blocks really like the 3.5--3.4 ratios. My 68 GMC has a 3.54 ratio-factory. My 68 longhorn, I put a 14 bolt in with the 3.42 ratio. Both trucks are big blocks
Old 01-30-2005, 12:33 AM   #5
69 longhorn
Yes, a mid 3's gear is perfect for a BB! I am running a 383 sb, with a 6spd trans behind it.....hoping that little stroker has enough "grunt" to pull a little taller gear. @ 29" tire, on the 3.40 gear , with .76 overdrive.....should set me really easy on the cruise range(3000 would be 100 mph).....that should keep up with the deisels running across Illinois 69L
