Old 01-29-2005, 08:47 PM   #1
skokie
skokie's Avatar
How to install a balancer?
Can someone tell me how I would install a harmonic balancer and what tools I would need?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 01-29-2005, 09:27 PM   #2
zooza
a good heavy hammer and a sturdy block of wood so you wont ruin the balancer. ( use the wood to cushion the blows with the hammer.
Thats the way ive always done it and no problems yet!
zooza is offline   Reply With Quote
Old 01-29-2005, 09:31 PM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
Use the above method except only hit the center of the balancer. Don't hit it outside of the rubber ring. I personally use this method, but you can buy a balancer puller. Some guys on the board don't like it cause several people have stripped the threads in the crank. I'd use the first method and be careful. If the motor is in the truck, you may have to use method #2.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-29-2005, 09:32 PM   #4
QKENUF4U
QKENUF4U's Avatar
put it on, line up the keyway, put the bolt in and use an impact wrench to draw it one the snout of the crank.
or
you could pound it on like said above.
QKENUF4U is offline   Reply With Quote
Old 01-29-2005, 09:43 PM   #5
86SILVERADO
86SILVERADO's Avatar
The most important thing is to get the nose of the crank and the inside of the balancer SHINY. If both the crank and the balancer are clean and smooth then with a little wd40 the balancer will slide on like butter. You should always deburr the keyway and I usually smooth the edges of the key a little bit so there is nothing to cause any binding or friction.
86 Silverado C10 back to 305 power!
67 C30 Dually Dump, with 350 transplant, Rockhauler
05 Duramax 3500
"If at first you don't succeed, try a bigger hammer"
Member of the 1-Ton club!
86SILVERADO is offline   Reply With Quote
Old 01-29-2005, 10:54 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've always thump them on with a big hammer and wood block.
If you use the bolt and an impact to draw it on, you're asking for real trouble. There was even a thread on here a couple of weeks ago where a guy ruined his crank doing it that way. I screwed up the threads in a 350 crank many years ago doing it myself.
They sell an installer tool to do it the "right" way.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-29-2005, 11:06 PM   #7
junkyardjohn
junkyardjohn's Avatar
A HARMOIC BALANCER REMOVAL & INSTALLATION TOOL IS ONLY ABOUT $25 OR $30. BUY ONE!! YOU'RE THRUST BEARING WILL THANK YOU FOR NOT BEATING IT WITH A B.F.H. . I ALSO COAT THE CRANK SNOUT, THE INSIDE OF THE BALANCER, AND ALL THE THREADS INSIDE THE CRANK & INSTALLATION TOOL WITH NEVER-SEIZE. WITH SOME BALACERS THAT ARE NEW OR OFF OF A DIFFERANT ENGINE, I HAVE TO HONE, WITH A BRAKE CYL. HONE TO GET THE PROPER AMOUNT OF PRESS FIT. IF THE PRESS FIT IS RIGHT OR EVEN CLOSE, YOU WON'T HAVE TO RESORT TO A SLEDGE HAMMER JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 01-29-2005, 11:37 PM   #8
skokie
skokie's Avatar
Would it be a good idea to put a little grease on the crank snout and on the back of the balancer? If not grease then what could I use. Tx firefighter are you talking about this tool here?
http://store.summitracing.com/defaul...6515&x=13&y=12
68 build thread
Old 01-29-2005, 11:54 PM   #9
skokie
skokie's Avatar
Or this one. It does the pulling and installing of the balancer.
http://store.summitracing.com/defaul...&Ntt=pro-66514
68 build thread
Old 01-30-2005, 12:34 AM   #10
86SILVERADO
Wipe a little assembly lube on the inside lip of the seal so that you will not burn it up when you first fire up the motor.
05 Duramax 3500
Old 01-30-2005, 12:50 AM   #11
skokie
skokie's Avatar
86Silverado what seal are you talking about? The one on the balancer or the one on the crank? Can you describe it?
68 build thread
Old 01-30-2005, 01:08 AM   #12
69 longhorn
its probably not the best way to do things, but back in the early t mid 60's (the chevs I grew up on), did not have a bolt to hold the balancer on. we used a block of wood & a BHF to solve the problem! I cant remember cant problems that it caused.....but an installer is the best route 69L
69 longhorn is offline   Reply With Quote
Old 01-30-2005, 01:59 AM   #13
zooza
Its up to you, there are a couple of ways to do it. I have never had any problems with the BFH method . but I cant say YOU wont! By the way, a BFH is a very helpful tool , sometimes! LOL
Old 01-30-2005, 02:07 AM   #14
neonlarry
neonlarry's Avatar
You can rent (borrow) a balancer installer from autozone. The seal is the one pressed into the timing chain cover.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 01-30-2005, 02:48 AM   #15
70short
Do it right JEEEEEEEEZ use A installer tool!!!
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 01-30-2005, 06:32 AM   #16
4x4Poet
Yeah, skokie, that's the tool. Note that it has a very thick, no doubt grade 8, washer between the nut and the dampner. The thickness of the washer prevents the nut from deflecting it which would cause misalignment of the dampner while you were trying to tighten it on the crank. Also, the nut is tall so as to grab enough threads on the rod without gouging or stripping either itself or the rod. And I see an intermediary washer that takes the turning torque of the nut and thereby allows the big, fat washer in contact with the dampner to never turn which prevents your dampner from being scratched. The shaft has fine threads for strength and to ease the dampner on slowly.
I've heard of folks making an installer with all-thread and a few thick, grade 8 washers. I've also heard of folks who boiled the dampner in water and then slipped it on with no tool. Gloves aren't tools, right? I've wondered whether boiling the dampner would harm the rubber between the dampner's two parts. That reminds me. I need to call TCI Auto to ask if I can boil one of their Rattler torsional vibration absorbers. I'd hate to loose the cool snake label.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 01-30-2005, 10:08 AM   #17
Tx Firefighter
Boiling water is only 212 degrees. That balancer is going onto an engine that can exceed that temperature often. Many late model GM vehicles turn on the fan about 220 degrees. No damage will be done by the boiling water.
Old 01-30-2005, 10:41 AM   #18
70 shorty
Where's my beer?
70 shorty's Avatar
If you can rent the proper tool for free at Autzone, why wouldn't you, assuming you have an Autozone close by.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 01-30-2005, 10:54 AM   #19
86SILVERADO
I was talking about the seal in the timing chain cover. You need to swipe a little grease on there so that when you first start up the motor it will have some lubrication this ensures that the seal will not get smoked by it being dry when the motor is first started. One other thing that has not been mentioned is if it is a used balancer and it has a grooved shaft it may need a sleeve. If the groove is only a couple thousandths you are O.K. but I have seen them where they are worn down like more than 1/16 inch deep groove. If so you will need to get a balancer sleeve to fix it so it will not leak.
05 Duramax 3500
Old 01-30-2005, 12:13 PM   #20
slogo
slogo's Avatar
I've rented tools from autozone many times, why buy when you can rent for free. unless your gonna be installing a bunch of them in the near future.
slogo is offline   Reply With Quote
