Old 01-31-2005, 05:38 PM   #1
JimKshortstep4x4
Question 72 AC truck with two inlets on tank sender
Can someone confirm the line routing for me on the two inlet tank sending unit?
On the two inlet sender units, I believe the smaller one is for the return line from the fuel pump. I cannot find any information on this setup and I would like to know if this is the correct routing.
I have not been able to find a listing on the fuel pump for the trucks but I am sure the later cars have them. My 69 El Camino has the return line coming back off of the fuel filter and I have seen fuel pumps on the mid seventies Corvettes with the fuel pump that has the return line on it.
Any help would be appreciated.
Jim
Old 01-31-2005, 05:51 PM   #2
smokekiki
Mike
smokekiki's Avatar
My 72 suburban and 72 blazer are set-up like that.You can get the fuel pump at autozone that has the return line.I don't know how good they are,I've not used one from there.They are listed under 72 c/10
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 01-31-2005, 08:42 PM   #3
JimKshortstep4x4
Smile
Mike,
I had not thought about checking Autozone! The Autozone site says that my local store has one for $12.99 with limited life time warranty.
Thanks for the information.
Jim
