04-11-2002, 09:32 PM | #1 |
64-69 are shorter than 70-72 shafts and 73-up are in between, you are screwed unless you make a spacer3/4" thick to go in between the brake backing plate and axle tube flange, wouldnt be all tht hard if you have a drill press and bandsaw or take metal stock to a local machine shop and have them cut out to your specs. one person here did this and it works fine and it saves another 12 bolt in a way
55.5" wide on pre-'70 housings width and 57" on '70-72 housings(back side of back plate to back sidde of other back plate) good luck ------------------ Randy- Lincoln, IL r68c30@hotmail.com -71 C-10 350/CH465/3.07 12 bolt 3.07/ trying to assemble! *Life and time permitting* :P -84 Z28 Camaro 5.0L 700R4, 3.73 rear -84 Firebird SE 2.8L. 5 speed Borg Warner -82 Firebird 350/TH350 *parting out 5.0LTPI '81 cutlass supreme brougham, and have lots of '67-87 parts of all kinds to sell or trade* *Paint is overrated © RSS Enterprises 2000 [This message has been edited by Fast68Chevy (edited April 12, 2002).] |
