Old 01-31-2005, 07:25 PM   #1
gregbr
Senoir Member
gregbr's Avatar
How to swap in a 68 hood??
I currently have a 70 GMC, but I would like to know what item will have to be changed to go to a 68 stylr hood on my GMC or a 70-72 Chevy. Thanks ahead of time. Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 01-31-2005, 07:53 PM   #2
71swb4x4
71swb4x4's Avatar
To do it on your 70 GMC you will have to swap out the radiator support and switch to a 67-68 grill. That's the only "bolt-in" way. Otherwise you could modify the leading edge of the hood of the grill to make it fit. The 67-68 grill sort of hangs over. Same concern with doing the same conversion on a 69-72 Chevy.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-31-2005, 08:06 PM   #3
71swb4x4
71swb4x4's Avatar
I am not too sure how these pictures will show up but they will give you a general idea. You are going to run into similar problems on Chevy's and GMC's. There are additional fender/grill problems when switching over a Chevy but that shouldn't hurt you since you have a GMC.
Old 02-01-2005, 05:29 AM   #4
gregbr
Senoir Member
gregbr's Avatar
So, with either Chevy or GMC, I need to change to a 67/68 Chevy radiator support and grille, then add the 67/68 Chevy hood. If adding this to a GMC the fenders are OK, but on a 69-72 Chevy I would also have to add the 68 Chevy fenders.....Correct? Doesn't seem that bad, and I think it looks better, especially with the 68 cowl induction hood.....ooooooooohhhh.
Old 02-01-2005, 09:06 AM   #5
71swb4x4
71swb4x4's Avatar
What you said is correct. You can use a 67-68 GMC hood as well.
Old 02-01-2005, 09:15 AM   #6
booth
Active Member
booth's Avatar
Question,
What is the differences in the rad. supports from '68 to '70 and is there any difference between the '67 chevy rad support and a '68 GMC besides the twin headlights?
Thanks,
Paul
'67 Chevy LWB (Running)
'67 Chevy LWB (Not Running)
'70 Chevy LWB (In Pieces)
'72 Chevy LWB (In Pieces)
booth is offline   Reply With Quote
Old 02-01-2005, 09:17 AM   #7
71swb4x4
71swb4x4's Avatar
I think the hood latch on the rad support is different from 69 up. I am pretty sure the dual headlights is your only difference on the Chevy/GMC rad supports.
Old 02-01-2005, 10:21 AM   #8
72gord
Never enough time!!
72gord's Avatar
If I'm not mistaken, you can take the dual headlight brackets off the GMC support and put the single Chevy buckets on, just drill out the spot welds holding the brackets on.
72gord is offline   Reply With Quote
Old 02-01-2005, 07:25 PM   #9
gregbr
Senoir Member
gregbr's Avatar
Thanks, I'm glad to have access to experts!! Greg
