Cantankerous Geezer
Fan shroud mounting
It appears that some sort of spacer is needed on the fan shroud screws. I don't know for sure, since my truck was butchered in some areas by the P.O. This is on my 69, 350 w/ a/c.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
If there were nuts on it for spacers, it sounds like the wrong radiator support brackets are bolted on the radiator support. There shouldn't be any spacers.
Merciless Butcher
The bottom of the shroud is attached to the radiator support with clips. I'll post a pic of them if you want.
Your Bought And Sold....I Got Your Soul! |
#4 | |
Cantankerous Geezer
Merciless Butcher
clips
The originals were a little bigger. GM discontinued them and replaced them with these.
Cantankerous Geezer
I took some pictures, hopefully one of y'all can figure out what's not right. There's about a 3/8" gap between the shroud and the upper support. It's a 4 core radiator.
Merciless Butcher
I think you may need the longer retainers for a four core radiator. Those look like the shorter retainers ( for a three core ). They should sit flat on the radiator. Maybe the pic is just deceiving. Sorry I was'nt able to help.
That was my first thought, as well, gonebad2. I would follow gb2's advice and count the rad's cores. If you have a 4-core rad, then a previous owner must have installed the rad without also upgrading to 4-core supports. I'm concerned with what the rad's tank bottoms look like in their 3-core rubber cushions and metal rad supports.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
Merciless Butcher
If you use the 3 core mounts with a 4 core radiator, you run the risk of vibration on metal to metal contact wearing a hole in your radiator.
Cantankerous Geezer
I found some problems by doing some measuring, old against new. The new radiator is 1/4" wider and taller. The new radiator cushions are 1/8" thicker than the old. Add that up, and there is an additional 1/2" of height. The ribs on the tank were against the core support at the top, took care of that by notching the flange on the core support. I haven't arrived at a solution to the height issue, yet. Need to do some clearance checks with the hood.
Also, the bottom edge of the fan shroud doesn't match up with the core support. Now, while I mutter some words about aftermarket parts. ![]()
I'm no small block expert but that looks nothing like the shroud on my big block trucks. It does look a lot closer to a shroud for a later year truck. I can post pics tomorrow if needed.
The shroud clips on my truck look different, they're bigger and stick out more than the ones gonbad2 posted a pic of. Anyway here's a pic of a 4 core rad. hold down with the correct hex head screw for holding the top of the rad. shroud to it, not sure if it's gonna help you or not. Sorry about the pics, the webcam is all I have to work with right now. FYI these are about 6.5" long, you might wanna measure the ones on your truck and see if they're shorter or not.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
Cantankerous Geezer
Thanks, Robert. Mine are 6.5" long.
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
#15 |
Cantankerous Geezer
Thanks a bunch, John. Now I have to wait and hope the weekend weather is good. I was getting ready to start machining some fittings, but a trip to the boneyard is easier.
#16 |
No problem sir, glad I could help.
