Old 02-02-2005, 01:33 AM   #1
low 84
low 84's Avatar
painting interior plastics
what do you guys use to paint interior plastics? i would prefer something i can get local. do you use a special primer or anything? i want this to turn out good and not scratch off and look like junk, if ya know what i mean
thanks
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 02-02-2005, 01:44 AM   #2
Jonboy
Slots go on anything!
I am pretty sure Oreillys carries SEM brand trim paint. They should be able to get you the correct primer and dye for the plastic. Just make sure the surface is clean. I usually clean it with wax and grease remover first, then use lacquer thinner and a scotchbrite pad. Go back over it with the wax and grease remover to get off what you might have scared up with the lacquer thinner, prime, and paint.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 02-02-2005, 11:51 AM   #3
crossy
Oh,you can't buy that new
crossy's Avatar
what Jonboy said is fine and way better than the methods that some people try :-( . at Auto body supply houses they do sell PLASTIC PREP & VINYL PREP that should be sprayed on first and it is available in spray bombs. There are LOTS of other 'enhancing' products including special etching/flexible primers ,but you could wind up with $300 worth of stuff that you only needed a dab of. if you plan to do door panels and a lot of other pieces like dash pad & such you should consider that. DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
84,C10 SWB-Yella,stock
86 K10 SWB-Red, hopped up 305,4/S
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 02-02-2005, 02:44 PM   #4
bagged81
Signals in the bumper.
bagged81's Avatar
When I took my dash to an upolstery shop to get it dyed, all they used was SEM interior paint so that's what I have used ever since.
All of these...
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 02-02-2005, 10:06 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
For the "do it yourselfer" SEM is the only way to go. Like Jonboy said the key to good adhesion is clean it, clean it, and clean it again. This can't be stressed enough. Adhesion promoter is good insurance too, just make sure you follow the directions on cure time....
Old 02-03-2005, 11:05 AM   #6
Jonboy
FWIW, I dyed all of the interior plastics in my 81 El Camino using DuPont products, and it was tough as nails. The downside is it requires spray equipment. The cleaning would be the same, though. I have had good luck with the SEM stuff as well. I did manage to get high as a kite off of the adhesion promoter. That is some noxious stuff. They really mean use in a well ventilated area....
Old 02-03-2005, 12:08 PM   #7
crossy
crossy's Avatar
danoxyfumeshadnooaffectonme
98 Vortec project.
94,3500,6.5L 4L80
Old 02-03-2005, 02:01 PM   #8
woody96
woody96's Avatar
Thumbs up Shoe dye.......
Guys, don't laugh , but I have used shoe dye..... I have some small places on the door panel uppers just below the windows that were sun washed out---got some Shoe dye in cordovan color--(matched exactly!), and dyed away...LOOKS GREAT! I don't know how long it'll last, but it sure looks great right now........
woody96 is offline   Reply With Quote
