Transfer case id
Can anyone help me ID my transfer case, it's in a 70 K10 there is a set of numbers on the case they are C99404 then a W underneath?
1970 k10 1971 C10 Gilbert Az |
An NP 205 will have a three bolt cover, center rear. The NP 203 was used 71-79. NP 205, 71-91. Np 208, 81 up. NP 241, 88 up. Early GM's used Dana 20. All info from Advance Adapters. What tranny ? Go to www.advanceadapters.com
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
Suburbans RULE!
I would say that it is a NP205. The number on mine is C-99404 with a A1Q underneath.
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. |
Pic of a 205 TC
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
#5 | |
NP 205 was used from 70-91 I believe The rest is correct
it takes many nails to build a crib, but only one screw to fill |
When I was building my '80 1 ton 4x4 daully , I found a "quick" way to ID 203s & 205s. The shift handle on a 205 is round all the way thru floor. A 203 is rectangular . I was looking mainly at 70s and early 80s stuff. Any exceptions anyone knows of?
Fender, as quoted, "all info from Advance Adapters." Those folks know more than I ever will.
user # 2756
![]() Join Date: Jun 2001
ford and dodge may have used NP203, but GM did not start until 1973 and the dana20 was only available in K5 w/ 6cyl and manual tranny.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
Interesting. The info from Adv. Adapters is listed just for GM/GMC trucks and Blazers.
What I should have said was that those people and many on this board know more than I ever will. Still learning.
