1972. while it is an extension so to speak, it is not the same material. Most are hard plastics or aluminum. They rub and wear holes through the metal. I have read this and been told this but I have no first hand knowledge of it. That is why I asked. Who knows for sure?
Smokekiki, yes for the filler. I have seen where the inside of the bed had to be cut and a cover similiar to the Blazer/ Subs was put in the bed. I have also heard that the angle is very flat and hard to get lines on and fuel in. I thought that 1 more inch above the frame might be of some help with the sending unit and lines. Without looking too out of place. The suspension lift will get the frame and body up 4" and the body lift would only be 1". This would not be too severe and keep my 33's and 4:11's. And I have a machine shop so I can cut any taller lift to anything I would need. I am thinking about buying urethane and making my own spacers. That way they are one piece, not a mount with an add on lift piece.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
