Old 02-05-2005, 09:06 PM   #1
badphish
67 to 72 on 86 frame?
I have a really nice 86 3/4 ton 4x4 frame that i want to but a 67 to 72 body on. How hard is this and what fabrication must be done?
badphish is offline   Reply With Quote
Old 02-05-2005, 09:12 PM   #2
Randy70C-10
Randy70C-10's Avatar
I would think that all you need to do is re-locate the mounting pads on the frame. Mudder67 has a 67 4x4 on a later frame, he's the expert.
Randy70C-10 is offline   Reply With Quote
Old 02-05-2005, 09:14 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The wheel base is different, and you'll have to make a custom body lift to make the body sit level on a non level frame.
Old 02-05-2005, 09:18 PM   #4
bisquik65
bisquik65's Avatar
I put a 72 body on a 79 4x4 frame,man what a job..... The 79 rear half of the frame was rotted beyond,we cut another 79 frame and welded,palted and bolted it together... Homemade body lift ,about 4 inches... Lot of work,but can be done....
bisquik65 is offline   Reply With Quote
Old 02-05-2005, 09:31 PM   #5
Mudder
Mudder's Avatar
Sorry to move your first post badphish but its going to the 4x4 forums.....
Welcome to the site, you will get some answers here.
Mudder is offline   Reply With Quote
Old 02-05-2005, 09:37 PM   #6
Mudder
Mudder's Avatar
badphish....pm me your email addy and I can send you some pics of all my mounts and a little bit of what I did. I can say that you will need a way of lifting, a torch, and a welder, to start with.
Old 02-05-2005, 10:12 PM   #7
badphish
thanks for the info mudder67. Does any know the wheel base of the 67-72 lwb and is it shorter or longer than my frames?
Old 02-05-2005, 11:35 PM   #8
72 CustomCamper
huh ???
72 CustomCamper's Avatar
The 67-72 lwb wheel base is 127" the 73-87 lwb wheel base is 133"...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 02-06-2005, 11:26 AM   #9
badphish
i have a couple more questions. Since i already need to shorten the frame what is the length of the swb? Will i have more distributor clearance issues with a big block than small block
Old 02-06-2005, 12:31 PM   #10
Mudder
Mudder's Avatar
Good idea having a engine sitting on the frame when u do this so you dont have issues with the distributor or valve covers.
