Old 02-04-2005, 01:25 PM   #1
COBALT
COBALT's Avatar
Rebuilding the automatic shift column...
During my failed brakes experiment a couple of weeks ago my shifter on the column has gotten completely goofed up. I think I've taken this thing apart three times, and every time I think I have it together like it's supposed to only to have problems with it later.
This time it's so goofed up I can barely shift, and that's only if I have my foot on the dash and I'm using my body's leverage to make it shift. Kinda hard to do.
Anyway, does anyone have a good drawn-out idea how this shifter is SUPPOSED to go together??? Forget LMC's picture of the column in their catalog. That's what's gotten me in trouble in the first place. I need to know what parts go where and in what order. I don't want to have to take this thing apart again because it's not correct. I'll order whatever parts I need.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 02-04-2005, 04:47 PM   #2
68jimmy
68jimmy's Avatar
Do you have a factory shop manual? When I rebuillt mine that's what I used as a reference... If not I could try and scan the pages in and send them to you.
good luck
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 02-04-2005, 07:25 PM   #3
COBALT
COBALT's Avatar
I have one but I think I lost it a long time ago. I would love a scan of it. I'll pm you.
Seattle, WA.
Old 02-06-2005, 12:34 PM   #4
68jimmy
68jimmy's Avatar
here it is...
Old 02-06-2005, 01:46 PM   #5
bigcdawg99
Can you make these factory columns work for a 700R4? If so how?
71 GMC Shortbed Fleetside (under construction)
"I like guns. You got a gun, you don't have to work out."
Chris Rock
bigcdawg99 is offline   Reply With Quote
Old 02-06-2005, 02:43 PM   #6
Bob Moore
Auto or Manual
I am confused as to which column you have Cobalt - stick or auto?
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 02-06-2005, 07:24 PM   #7
COBALT
COBALT's Avatar
Automatic 3 spd. for TH400
Seattle, WA.
Old 02-06-2005, 07:32 PM   #8
COBALT
COBALT's Avatar
Part of the problem is all of the parts in the column sort of depend on each other for smooth operation. If the washers, bearing, etc get put in wrong then the shifter might bind up, which is part of my problem. The diagram above shows how the shifter goes in, which I think I have right. The problem is the rest of the parts above the shifter that may not be allowing the shifter to move forward before sliding to one of the positions. If I know how all of the column goes together maybe I can find out why it's binding up and put it together right.
Seattle, WA.
