Old 02-08-2005, 03:58 PM   #1
el curioso
el curioso's Avatar
4link
i plan on ordering a four link from suicide doors.com and i was wondering where should i measure from to get the exact mesurements to order the kit. this is what i plan on ordering
http://www.*****************/products...canti_bars.htm . what do you guys think ? good or no good for my 72 long bed?
el curioso is offline   Reply With Quote
Old 02-08-2005, 04:58 PM   #2
fastbagged68
fastbagged68's Avatar
Get there mount they use for the parrel 4 link in the front. Makes it alot easier to mount your front lower bars. You will need to make a crossmember for the upper bars since you can't weld to the top of a stock gm rearend. You will probably be fine with a 21-3/4" bars on the lower. That is what air ride uses for there bar length. Call Air Ride Tech and ask them what there bars are. I know there 4 link will work with your truck.
fastbagged68 is offline   Reply With Quote
