Old 02-05-2005, 04:44 PM   #1
tbirdman88
87 short crewcab
tbirdman88's Avatar
question about shortie headers 73-87
is there any one running shortie headers on their 73-87 chevy trk?
if so what were they supposed to fit. im looking at some for 88-98 trks, but dont know if they will fit. any help appreciated.
thanks
donnie-tbirdman88@msn.com
tbirdman88 is offline   Reply With Quote
Old 02-05-2005, 05:19 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
I'm not running them, but I would assume these from Early Classic Enterprises would fit just fine....
Old 02-05-2005, 09:04 PM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
http://207.44.196.117/vboard/showthr...=bluex+headers
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 02-05-2005, 09:11 PM   #4
cochino12
It followed me home?
cochino12's Avatar
I've got some sanderons on mine
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 02-05-2005, 10:04 PM   #5
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Im runnin Edelbrock TES on my truck and i love 'em fit is perfect you can still change the spark plugs!
Why would you look at a header thats not for your application??
Just about every header Mfg. makes a header for our truck's.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 02-07-2005, 03:32 AM   #6
bluex
bluex's Avatar
Originally Posted by Slonaker
I still love these headers. For the price I've very pleased with them. You have to be careful with #1 & #2 plugs though. You cant get a plug socket all the way on it and when you go to tighten it will crack the plug. I was having an intermittent miss under load and that was my problem. I spent $90 on a new cap, rotor and MSD wires b/c I thought that was it. Changed the plugs while I had it all apart and found that #2 was cracked. Cracked the new one putting it in too. The #1 is at the same angle so I only use a wrench on those two now. You have to use a wrench on 5 & 6 too b/c they are behind the two tubes. It still dose not take any longer to change the plugs than it did with the regular manifolds.
bluex is offline   Reply With Quote
Old 02-08-2005, 06:13 PM   #7
truckinbean
Those Sanderson's from Early Classic Enterprises look like the cc10's that I have on my 77 blazer. The collecter is a little close to the firewall on the driver's side and the collecter bolts are a PITA to get to on both sides. I've also had problems with collecter gaskets leaking, but I think it's because the muffler shop didn't line up the down tube very good. I also have to get under the truck to change the #5, 7, 6, & 8 spark plugs, but that might be from the plug wire looms being in the way on top.
truckinbean is offline   Reply With Quote
