Old 02-08-2005, 08:08 PM   #1
jetfixr
Drive shaft questions 700r4 swap
I have a 70' SWB with a manual tranny (4 on the floor, 1st is a granny gear). It is a city truck and will never see too much harsh duty. Decided that a 700r4 was the route to go. I picked up a Bowtie overdrives transmission and getting ready to do the swap. What type of issues can I expect with the drive shaft? Is there any existing driveshafts that will work? Should I just try and have mine shortened, or maybe just scrap it all together and have a new one-peice made?
jetfixr is offline   Reply With Quote
Old 02-08-2005, 10:19 PM   #2
roj2323
you will have to have the shaft cut. any good driveshaft shop will shorten it and install all new ujoints and carrier berring for around $200. for the trans install look in the f.a.q. board.
ondrew
roj2323 is offline   Reply With Quote
Old 02-09-2005, 03:30 PM   #3
67pro-street
67pro-street's Avatar
First of all, your driveshaf yoke on the four speed has a different number of splines. the bowtie tranny will have either thirty or twenty seven splines, probably 27. so you will need to get a new yoke for that. dont plan on getting one from a junyard either. at least where i am from no one wanted to part with just a yoke unless i was buyng the whole tranny, so you will probably end up spending about 70 bucks for a new one. you should also ask the shop you are going to have shorten your drive shaft how they want you to measure the new distance before you take it to them (just to save some time) other than that, everything should bolt up again without any problems. if you have any more questions, feel free to pm me or email me as i just did this swap over my christmas break.
67pro-street
67pro-street is offline   Reply With Quote
Old 02-09-2005, 04:21 PM   #4
superchevy
Got big-block?
superchevy's Avatar
I just had my '77's driveshaft shortened for a T400 to 700R swap.
Shorten shaft, new u-joints, new 700 yoke, and balanced was $295.
SC
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
