06-27-2002, 04:49 PM | #1 |
equal tire balance powder??
Have any of you guys tried equal to balance your big meats? I'm always losing weights off of my 35"s and I heard this stuff might be pretty good. Any thoughts?
Thanks, Chris
webmaster, www.steelsoldiers.com 1984 M1009 CUCV Military Blazer w/ Caddy 500 big-block and a 1970 M35A2 2.5-ton 6x6 cargo truck w/ 478ci multi-fuel straight-six engine. Both in desert tan CARC paint from Operation Desert Storm. |
06-27-2002, 11:57 PM | #2 |
I have a friend that has a set of 35x12.50x16.5 BFG mudders that have equal in them. Has helped the tires to last around 60,000 miles on a 81 k30 chevy. another friend has equal in 35x12.50x15 BFG AT's they have run in the 60,000 mile range on a 86 K5 with a diesel in it. I am going to run equal in my 35's when I get the k20 burb finished
Wade "DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project 2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's 79 RS Camaro |
06-28-2002, 01:53 AM | #3 |
i had equal put in my 35 boggers and it was horrible, i know the tires are hard to balance but i mad em do it the old way and it was much better. Might be better on the tires like a mt.
06-28-2002, 09:30 AM | #4 |
Never had a problem with my tires or the weights coming off. My rims have a good edge for the weights to bite onto. Never heard of the equal stuff.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
07-08-2002, 02:29 AM | #5 |
Registered truck nut
My buddy tried it in his 35x14.50x16 Swamper SSR's and didn't like them. He went back to weights. Swampers seems to be harder to balance so that may be the problem
MOUNT VERNON, WASH. STATE Need a part? Just PM me |
07-09-2002, 02:09 PM | #6 |
Recovering Truck Driver
we tried the equal thing in semi truck steer tires once, we found that if you don't use dry air, the powder has a tendency to stick together and turn into a big glob, totally defeating the purpose....
believe it or not, golf balls were the best thing we found to balance truck tires...just drop 3 or 4 in there and they will balance out the tire with centrifugal force.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
07-11-2002, 07:08 PM | #7 |
I have equal in my 265 x 75 x 16 on my 92 burb also. i have no problems. I put a in line water filter(like you see on paint guns) on my air chuck that takes any moisture out of the air i put in my tires.
07-16-2002, 12:46 PM | #8 |
Equal!
The trick to get this to work is keeping it dry. I wont work if moisture is present.
