02-10-2005, 12:53 AM | #1 |
Where does this wire go ?
It comes from the harness along with the ignition wires. Kind of a brown/ grey color.
Thanks, Bret
71 Custom 20 Deluxe..soon to be SWB 1/2 ton 1 incredible wife 2 great kids |
02-10-2005, 01:00 AM | #2 | |
Bloo
heat lever assembly light, goes behind that little glass peice that says def, heat, air fan on it... i can try to get pics of mine tomarow if youd like
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
02-10-2005, 01:02 AM | #3 |
Is the wire hot. If so it might be the cigarette lighter pwr wire.
Real Trucks are Built not Bought Building: 1981 GM SB LowRider 1985 GM K3500 3+3 1981 GM K2500 SSB 1980 GM K2500 X-BC Hydro 1979 GM K3500 3+3 1976 GM K5 Blazer 1970 Custom 10 http://bc4x4.com/ |
02-10-2005, 01:04 AM | #4 |
I am confused ( as normal ). I have a wire and bulb to the area you describe already.
02-10-2005, 01:10 AM | #5 | |
Bloo
hmmm... thats interesting.... i dont know then, maybe cig lighter or glovebox light?
02-10-2005, 01:25 AM | #6 |
Saving 1 truck at a time!
No. 18 gauge tan goes to the brake warning switch and the brake warning light on the dash (but the light should be in the bundle connector to the back of the dash). There is another tan wire from the ignition switch that goes to the outside aux. fuel tank.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
02-10-2005, 01:27 AM | #7 |
it might be the wire for the fan motor switch, on the back of your heater controls you have one lever that when pushed to one side turns the fan motor on, and also has a cable running down to the firewall that opens the flap enabling the blower motor to vent the cab
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
02-10-2005, 01:35 AM | #8 | |
Thanks all !
02-10-2005, 05:29 AM | #9 |
Go to this web site.
http://www.geocities.com/chevroletc1070/wiringdias.html You should find your answer there? Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
